20 Most Recent Stanley Lawn Mower. 54 in. 24 HP Kawasaki FR691V Heavy Duty Zero Turn Questions & Answers
Make sure it has the right amount of oil in the crank case, if over filled the oil will foam and flow out any place it can, Worn piston rings can cause blowby into the crank case , causing oil to escape from the dipstick tube.
Stanley Lawn... | Answered on Feb 08, 2017
On the pivot end of the bladed knife is a black plug that says pull. They actually mean "Push". push it away from the knife body and rotate the handle half it's mounted in, down. The body will rotate in half , revealing the utility blade and more blades in the rear storage.Also note the blade depth adjustment has a locking detent. You have to push it to the right to unlock the utility blade.and push it to the right when retracting to fully retract and lock the utility blade.
Stanley Garden | Answered on Jun 14, 2019
Is tranny and various speeds working properly? How about the throttle control? Do you have it set for higher speed?
Stanley Garden | Answered on Aug 25, 2017
Try tilting the machine backwards for a few hours. It may be oil on the piston that is causing a vaccum
Stanley Garden | Answered on May 05, 2017
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
Stanley Garden | Answered on Dec 25, 2016
This is a terrible tool took it apart to get the blade out of the handle and haven't been able to get it back together again.
Stanley Garden | Answered on Jul 24, 2016
Try manufacturer web site.
Stanley Garden | Answered on Jun 12, 2016
Hi Chris:
It is usually easiest to rest the weight on the tailgate of a pickup truck (or some other device) and then slip out of the harness.
Another technique is to lift bend forward while at the same time rising one shoulder and lowering the other. That will create "slack" on the low shoulder side allowing you to get that arm out.
Cheers
Stanley Garden | Answered on Mar 19, 2016
Stanley Lawn Mower. 54 in. 24 HP Kawasaki FR691V Heavy Duty Zero Turn Logo
2 questions posted
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
View Most Popular
Stanley Garden
  • Stanley Garden
Most Popular Question
oil blow out dipstick tube when its
  • Garden
