20 Most Recent Scag SFZ52-26BS Freedom Z Zero Turn Rider Questions & Answers
sounds like you got one wire in the wrong position on the switch. starter wire is on run position of switch not crank position
Scag SFZ52-26BS... | Answered on Mar 04, 2019
I would like to know the same thing! I have that exact issue
Scag SFZ52-26BS... | Answered on Sep 23, 2016
It is most likely the switch. I had the same problem and that fixed. I found the switch on Amazon for less than $20. Stens 430-798 PTO Switch Replaces Scag 483957
Scag SFZ52-26BS... | Answered on Sep 30, 2014
for safety reasons only
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Scag SFZ52-26BS... | Answered on Jul 26, 2014
Fuel filter
If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
Scag SFZ52-26BS... | Answered on May 30, 2014
Assuming that you have checked the spark plug and confirmed that it has not completely failed, the most common reason is the magneto on that side has failed. (There is a separate magneto for each cylinder).
To replace a magneto, you'll need to look up which part is used on your particular engine. (You will need the brand (Briggs, etc.) and the complete engine model and type numbers from the id tag on the engine).
Then go to an intrernet parts seller and look up your part number. One place you can start at is at PartsTree
http://www.partstree.com/parts/
Once there, click on the engine icon for your engine and drill down until you find the correct magneto part number.
Replacing the magneto is simple, removing the top engine sheet metal cover involves removing a few bolts, and both magnetos are then readily available.
When installing the new magneto, you first screw it down at the furthest point away from the flywheel. Then rotate the flywheel so that the magnet is aligned with the new magneto.
As part of the new magneto, you will get a thin sheet of cardboard that you hold against the flywheel magnet and loosen the new magneto, allowing it to be pulled again the magnet (with the special cardboard spacer in between).
Use care as the magnet is quite strong and the magneto will be pulled to it with a strong force.
Now firmly tighten the two screws that mount the new magneto and slowly rotate the flywheel to remove the cardboard. Replace the engine top cover and your done.
Scag SFZ52-26BS... | Answered on May 25, 2014
Recheck your connection at the battery and the solenoid. The clicking noise is probably the solenoid. The starter may have a shorted out field coil or armature. This will cause a starter crank over sometimes but it will have a bad spot where it will not crank. Check connection at starter as well.
Scag SFZ52-26BS... | Answered on May 09, 2014
???????????????????????????? YOUR DESCRIPTION BAFFLES ME
Garden | Answered 2 days ago
Make sure you are using new gas, check the spark as often the induction coil goes bad and needs replacing.
www.jackssmallengines.com > equipment > list > Exact-Replacement-...
Tiller Exact Replacement Belts - Jacks Small Engines
Type: Raw edge. Width: 1/2" Length: 22" Application: Drive Equipment Type: Tiller Available only as a set from Troy Bilt Requires 2 belts for Troy Bilt GW-1128. www.amazon.ca > Replaces-Craftsman-Poulan-Wizard-132801
1/2 X 52" Belt Replaces Craftsman, Poulan, Yard Man, Wizard ...
This is a general purpose Rotary 1/2 X 52" belt that fits and performs well replacing the 132801 tiller tine drive belt. Part 132801 was used on several brand of tillers made by AYP including: Craftsman, Poulan, Husqvarna, Wizard, Yard Pro, Roper, and more.
Garden | Answered on Jan 14, 2020
The ignition module is underneath the blower housing recoil starter. Remove whatever you find necessary to get to the blower housing.
Air gap is 0.016 to 0.020 and mounting bolt torque is 80 - 100 lbin. Do NOT over tighten as threads in block easily strip.
See following for more detail.
https://www.mymowerparts.com/pdf/MTD-Service-Repair-Manuals/MTD-Big-Bore-Engines-78-277cc-83-357cc-90-420cc-Repair-Manual.pdf
Your description suggests a part blockage or restriction in the fuel line or perhaps the fuel tank breather isn't allowing air into the tank causing a depression...
Garden | Answered on Jan 13, 2020
Read your question. Maybe you could be more informative.
Garden | Answered on Jan 11, 2020
https://www.husqvarna.com/us/search/?searchText=-Wb48s
502 94 53-01 V-BELT
Scag SFZ52-26BS Freedom Z Zero Turn Rider Logo
8 questions posted
Top Scag Garden Experts
Dennis Webber
ray gallant
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Scag Garden Expert? Answer questions, earn points and help others
View Most Popular
Scag Garden
  • Scag Garden
Most Popular Question
scag zero turn kawasaki 23hp engine put
  • Garden
