20 Most Recent none CHUNGHOP RM-139EX Universal Remote Control Questions & Answers
Download the
CHUNGHOP RM-139EX Universal Remote Control manual from here Chunghop RM 139EX
none CHUNGHOP... | Answered on Sep 18, 2017
Try to find this code in the Chunghop RM-139EX remote control manual
Chunghop RM 139EX
Click here to download the user manual to your remote control. It has all details.
none CHUNGHOP... | Answered on Apr 03, 2017
http://www.mypostcodefinder.co.uk/wiltshire/swindon/4jb-oxford-road.html
none CHUNGHOP... | Answered on May 04, 2015
Many many strange things can be bought with points.
none CHUNGHOP... | Answered on Mar 10, 2015
To which device do want set-up code with this remote control? If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order.Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window.It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
none CHUNGHOP... | Answered on Mar 02, 2015
Use Sears Code 0205 for the 40 inch LED it works!
none CHUNGHOP... | Answered on Jan 20, 2015
Some codes to check with LG brand TVs are 0168 0181 0182 0195 0235 0250 0303. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
none CHUNGHOP... | Answered on Mar 20, 2014
The best universal remote is the Logitech Harmony remote. It never gets outdated and will work on any tv. You use their website to program the tv and any other component you have hooked up to it. For example: If you get a new bluray player to replace your old dvd player you simply log back on the website, connect the usb cable that comes with the remote and reprogram the remote.
The manufacturers website carries the codes for common sets.
none CHUNGHOP... | Answered on Jan 13, 2014
Codes for Sony TV are: 0028/0119/0126/0127/0128/0129/0130/0182/0199/0228/0260/
0013 0002 0071 0380
none CHUNGHOP... | Answered on Oct 16, 2012
First ,what is the current input source? If the source isn't connected to the coaxial antenna (RG59) jack, then most TVs will not have the channel scan option available.
Next, the only L2614XW02 I've found is a version of the Maxent MX-26X3 TV. This TV only has an analog tuner. Very few analog OTA stations are still broadcasting and those that are use low-power transmitters. Thus you have to be close to the signal source to receive the broadcast. For most stations, you'll need an OTA digital to analog tuner converter box. Similarly, if you have cable and use a set-top box, that will not be a signal that the TV will tune in directly. Use the set-top box to search for channels.
I hope this helps.
(Note: the tuner can be damaged by a surge that came through the antenna. My household lost a converter box and a TV following a nearby lightning strike. If this is the case, you may need to replace the TV or at least the main board. ShopJimmy lists that part as out-of-stock, https://www.shopjimmy.com/maxent-dpwb11497-ml-b-main-board-for-mx-26x3-l2614xw02/ )
Televison &... | Answered 3 hours ago
ask google for the code list
Televison &... | Answered 24 hours ago
nordmende nu323lv lslcd it wont power on and is stuck in standbye any ideas???
Televison &... | Answered Yesterday
How to program Dish remote to receiver?
How to Program Your DISH Remote Control
  1. Press the Home button on your DISH remote twice. ...
  2. Select Settings from the on-screen menu.
  3. Select Remote Control from the on-screen menu.
  4. Use the on-screen menu to select the device you want to pair.
  5. Select the Pairing Wizard option from the menu.
More items...
How to Program a DISH Remote ' CableTV.com
Remote Control
www.dish.com > voice-remote > pdf > voice-remote-quick-start-guide
PDF control, indicating it has paired with your. DISH receiver. AUX in. SAT. TV. 4 Press the SAT button on the side of the remote control. 3 Open the front panel of your ...
VIDEOS
https://www.google.com/search?q=Programming+a+Dish+Evolve+Remote+to+the+Receiver.
none CHUNGHOP RM-139EX Universal Remote Control Logo
22 questions posted
Top none Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a none Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • none Televison & Video
Most Popular Question
need code led tv seiki
  • Televison & Video
