DX-80 Time Change Instructions
Software Revision F32 and later
From the attendant station or an phone with attendant password:
1. Press Feature #0 from the telephone dialpad. You will be prompted to enter the Tenant Group
number. This is typically 1, however it can be set for Tenant Group 1-3.
2. Press Save and enter in the attendant password (default is 9999), then press Show.
3. Press the Next option until the display prompts you for the System Time. Press Show.
4. The last 2 digits of the year will be displayed. If you do not need to change the year, press Next. If
you need to change this value, press Chg, enter in two digits for the year and press Save then Next.
5. The current month setting will be displayed. If you do not need to change the month, press Next. If
you need to change this value, press Chg to cycle through the 12 months. When you reach the
appropriate setting, press Next.
6. The display will show the currently programmed day of the month. If you do not need to change the
date, press Next. If you need to change this value, press Chg, enter in two digits for the date and
7. The day of the week (Sat - Sun) will now be displayed. If you do not need to change the day, press
Next. If you need to change this value, press Chg to cycle through the days of the week. When you
reach the appropriate setting, press Next.
8. The current hour will be displayed. Press Chg and enter in two digits for the hour in military format.
Press Save and Next.
9. The display will now show the programmed minutes. If you do not need to change the minutes,
press Next. If you need to change this value, press Chg and enter in two digits for the minutes (01-
59). Press Save then Next.
10. You will be returned to the top level off System Time. To exit Attendant Administration, pres
On/Off button twice.
Software Revision F2x
From any telephone:
1. Press Feature # * and enter in your password. (Default password ########).
2. Press Show and enter 08 14.
3. Press Save then Show.
4. The option to change the Year will appear. If you do not need to change the year, press Next. If
5. The option to change the Month will appear. If you do not need to change the month, press Next. If
you need to change this value, press Chg, enter in two digits for the month and press Save then
Next.
6. The option to change the Day will appear. If you do not need to change the date, press Next. If you
need to change this value, press Chg, enter in two digits for the date and press Save then Next.
Printed in the USA Page 2 of 2
7. The option to change the Weekday will appear. If you do not need to change the weekday, press
Next. If you need to change this value, press Chg, to select the weekday, and press Next.
8. The option to change the Hour will appear. Press Chg and enter in two digits for the hour in
military format. Press Save then Next.
9. The option to change the Minutes will appear. Press Chg and enter in two digits for the minutes and
press Save.
10. Press the On/Off button to take the phone out of programming mode.
2 questions posted
2 Questions
