20 Most Recent FoodSaver Food Saver Vacuum Sealer SmartSeal V3460 Questions & Answers
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
FoodSaver Food... | Answered on Mar 07, 2016
That may be very hard to do without changing the dye color. The longer it is in there the worse it will be.
In order:
1) try tuff stuff foam cleaner you can buy at Wal mart
2) if that does not work - try mineral spirits to see if it comes out. Finish with Tuff Stuff to get residual mineral spirits out
3) if those 2 do not work - this is the last ditch effort - you will need a commercial solvent. May take the dye out and hurt the carpet fibers.
Good Luck!
Vacuums | Answered Yesterday
Put a piece of clean fabric over the wax and use a warm iron on top of the fabric to melt the wax, rub and repeat if necessary
Request from the manufacturer/distributor
Vacuums | Answered 2 days ago
Vacuum cleaner hose can be bought off the roll in some repair establishments, usually those places that primarily service the needs of trade customers.
The trouble is, although a length of hose can be bought, it isn't helpful in every case as manufacturers these days tend to weld the end fittings to their hoses making it almost impossible to separate, forcing people to pay inflated prices for replacement hoses as a spare part from the vacuum cleaner manufacturer or an aftermarket supplier.
Vacuums | Answered 3 days ago
WITH NO WAY TO TEST WE CAN NOT GUESS
Vacuums | Answered on Nov 23, 2020
If you have mostly hard floors you can't go wrong with a Miele canister vacuum. They have many models out. I would suggest one with a 14" horse hair floor brush. they are german made and last for years. Don't buy a Dyson they are very harsh on hard floors and your carpet.
Vacuums | Answered on Nov 20, 2020
overuse no doubt so buy a new one :)
Vacuums | Answered on Nov 18, 2020
fixya does not source vacuum cleaner parts. Check with a repair shop.
Vacuums | Answered on Nov 10, 2020
May you explain more what happen? Did a cap get stuck in the hole? If so take a household vacuum and use the attachment tool to suck the cap out.
Need expert help?
https://www.6ya.com/mr.mike
Vacuums | Answered on Nov 05, 2020
Contact Genie directly to request the manual for model SV300Q.
Vacuums | Answered on Oct 29, 2020
Contact Chi directly to request the manual.
How to Repair a Hoover FloorMATE ' Hunker
www.hunker.com > ... > Other Home Appliances
Sep 7, 2018 - The Hoover FloorMate makes cleaning floors easy. ... The Hoover FloorMate takes over where traditional dry vacuum cleaners leave off. ... If water puddles behind your FloorMate, make sure the cleaning solution tank is in the ...
See questions and answers - Amazon.com: Customer ...
www.amazon.com > ask > questions > asin
Hoover FH40160PC FloorMate Deluxe Hard Floor Cleaner, Wet Dry Vacuum, Silver ... will drip from brushes and underside of the product after use and puddle.
Hoover FH40160PC FloorMate Deluxe Hard ... - Amazon.com
www.amazon.com > product-reviews
Hoover FH40160PC FloorMate Deluxe Hard Floor Cleaner, Wet Dry Vacuum, ... YOU AFTER PURCHASE AND LEAVES IT UP TO AMAZON TO DEAL WITH.
Vacuums | Answered on Oct 24, 2020
FoodSaver Food Saver Vacuum Sealer SmartSeal V3460 Logo
8 questions posted
Top FoodSaver Vacuums Experts
ray gallant
Larry Ng
Larry Ng
Lawrence Oravetz
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
View Most Popular
FoodSaver Vacuums
  • FoodSaver Vacuums
Most Popular Question
cannot get vacuum
  • Vacuums
