20 Most Recent Delta Victorian T2755-NNLHP Bathroom Roman Tub Faucets Pearl Nickel Questions & Answers
2answers
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
3/6/2019 12:33:58 AM • Delta Victorian... • Answered on Mar 06, 2019
We have a kitchen faucet that is similar to this
I personally would not call this plumber back if that was his prognosis. Sounds like it might have a stripped thread you could possibly try some loctite on the portion of thread before tightening or just replace the unit especially if it has age on it's side. Good Luck..
11/26/2010 9:41:43 PM • Delta Victorian... • Answered on Nov 26, 2010
How to either break or cut off a Delta single hand tap. I've tried everything to remove it?
Taps lock up and rust. Although the outside is nice and shiny chrome, the inside is brass and they use steel screws that rust in place. Turn off the water, replace the whole thing. Take the parts back where you got them and buy the new one. When you get the new one, remove screws and removeable parts and grease them up with Vaseline.
2/12/2023 7:16:08 PM • Delta Plumbing • Answered on Feb 12, 2023
Brand new Delta faucet and battery case will not stay closed. Only one week old!
Question moved from Cars and Trucks to Delta Plumbing. If it is brand new, you need to contact Delta under warranty rather than Fixya. https://www.google.com/search?q=Delta+faucet+and+battery+case+will+not+stay+closed ..
10/30/2022 3:18:58 PM • Delta Plumbing • Answered on Oct 30, 2022
My delta touch faucet only has small stream what do I do
no info generic answer poor water pressure---valve /water line clogging / failing
4/14/2022 12:55:02 PM • Delta Plumbing • Answered on Apr 14, 2022
Delta cartridge for double-handled faucet will not seat properly.
There a little plastic tab on the cartridge that will line up with a notch in the valve body?...allowing it to go all the way in
3/6/2022 4:06:29 PM • Delta Plumbing • Answered on Mar 06, 2022
Faucet doesn't leak exactly, but...
The classic signs that it needs a new ceramic cartridge and o-rings.
1/5/2022 12:16:17 AM • Delta Plumbing • Answered on Jan 05, 2022
What is replacement number for washers for delta 418sswf
Contact delta they will have that information
9/21/2021 8:45:57 PM • Delta Plumbing • Answered on Sep 21, 2021
2answers
Delta Faucet RP13740 Bidet-Vacuum Breaker leaks from the top.
For me, the issue was the washer that's exposed on the underside of the circular brass piece that's exposed when you unscrew the top (I wasn't able to find any documentation that explains what anything is called). My washer looked fine, but I removed it, added some silicone o-ring lube i had and re-assembled. Stopped leaking.
9/3/2021 1:59:59 AM • Delta Plumbing • Answered on Sep 03, 2021
What degrades in Delta faucet cartridge #RP50587,to warrant 'new' purchase
Water condition, could be a variety of things with water.
7/13/2021 6:25:52 PM • Delta Plumbing • Answered on Jul 13, 2021
Have a 2011 delta purchased kitchen faucet, 2 handle, no handle set screws, how to remove handle
They should simply twist off (unscrew)from the base. Assuming thus is a two handle faucet the "body" right below the handle will simply unscrew reveling the cartridge underneath. Hope this helps!
2/10/2021 2:51:20 AM • Delta Plumbing • Answered on Feb 10, 2021
3answers
Delta kitchen faucet called the shiloh with low water pressure
There is normally a filter at the end of the faucet outlet. They usually unscrew. its usually a fine mesh screen with a plastic backing mount.
1/14/2021 11:23:38 AM • Delta Plumbing • Answered on Jan 14, 2021
I have a delta touch faucet and the blue led light stopped working. The red is still lighting and the touch feature is working properly. How can I fix the blue led light?
  • Solid Blue - Normal operation, "Touch" mode is activated.
  • Flashing Blue - Normal operation, the hands-free mode is activated.
  • Solid Red - Warning mode - Replace batteries as soon as possible. While the water is running Solid Red LED is illuminated. When the water is off, the Red LED flashes once every 5 seconds. The faucet operates normally, solenoid valve is open.
  • Rapid Flash Red - Alert Mode - Battery Failure Imminent. The Red LED flashes once a second. The first time the faucet is used, the Red LED will turn ON, the solenoid valve will be opened and remain open. The manual valve must be used until the batteries are replaced.
  • Solid Red - Lockdown Mode - Replace Batteries. Extremely Low Batteries - The RED LED is ON, and water will not flow. The solenoid valve is closed and faucet will not operate until batteries are replaced.
  • Long Flash Red (2 seconds on / 2 seconds off) - Board error, replace electronics kit, RP53230 See manual bypass of electronics section of Installation instructions.
7/19/2020 5:10:18 PM • Delta Plumbing • Answered on Jul 19, 2020
How to remove handle on delta kitchen faucet that has no set screw
https://www.youtube.com/watch?v=unqc06D5Q6Q
5/8/2020 5:31:50 PM • Delta Plumbing • Answered on May 08, 2020
No blue light & comes on when not touching it/ Delta touch kitchen faucet / what is wrong - have to keep faucet turned off
https://www.deltafaucet.com/files/live/sites/delta/files/company/concierge/Touch_troubleshooting_guide.pdf "Ifthesesolutionsarenotabletoresolvetheissue,pleasecontactourDeltaTech2O ConciergeTeamat1-844-923-5368 IFNOSOLUTIONABOVERESOLVESTHEISSUE,PUTFAUCETINMANUALMODEBYUNPLUGGING THEBATTERYBOXWHILETHEWATERISRUNNINGUNTILRESOLUTIONCANBEACHIEVED"
6/9/2019 1:39:47 PM • Delta Plumbing • Answered on Jun 09, 2019
I have installed the delta B112915C. The issue is getting the handle to stay on. The extension piece keeps falling off the valve cartridge. How do I keep them together??
You need to install the screw that came with item, it goes under the handle thru the extension and into cartridge. Refer to instructions.page 3. qk5krxajihraoapoi3zsan40ueqbvcpnowdvswq5rplcc5jjjt9xtd0q73fiheilr206ekaef1bbswnqkaf4ggaabui7kgbwcaadeaaaafvpkvylsawb+ibgaa+ig8cwcqbqibaaa6yjjomwucgc8qdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacradeaaaaaqgranaaaaaaqgranaaaaaeqgramaaaaakqhraaaaaebkqdqaaaaaebkqdqaaaabebkqdaaaaajeb0qaaaabazea0aaaaabazea0aaaaarazeawaaaacr8f8dkgsefmplxo4aaaaasuvork5cyii= https://media.deltafaucet.com/MandI/88723%20Rev%20B.pdf
6/5/2019 2:49:34 PM • Delta Plumbing • Answered on Jun 05, 2019
Delta touchless faucet turns on just fine, but there is a several seconds delay when I turn it off. I did replace the batteries
Open the battery case and realign the batteries with the positive and negative poles in the right positions according to the layout in the battery compartment. Close the battery compartment. Make sure it locks completely before continuing.Locate the reset button, if any, on or near the battery compartment, after changing out batteries.Push the red reset button to reset the faucet.Test the faucet to ensure the reset corrected the problem.TipNot all automatic faucets have red reset buttons. Some faucets just require inserting new batteries or realigning the batteries in the compartment to complete a reset. on the faucet. Check the instructions that came with your automatic faucet or locate the user's guide online at the manufacturer's website.
5/8/2019 5:56:03 PM • Delta Plumbing • Answered on May 08, 2019
Delta Victorian T2755-NNLHP Bathroom Roman Tub Faucets Pearl Nickel Logo
4 questions posted
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
delta faucet loose moves right left
  • Plumbing
