20 Most Recent Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Questions & Answers
Delta swivel faucet won't swivel
Take handle off it has set screw that holds it on top of faucet after handle is off it has a locking collar they may have it to tight you can get a little wrench from hardware store that turns it. most are plastic so be careful if you try to move it you may try a little at a time to see if it free's up.
5/15/2019 1:59:06 PM • Delta Model 470:... • Answered on May 15, 2019
KWC faucet leaking around the main stream of water
Yes, go to HD or Lowe's and buy a new one. Be sure to take the old one for comparison.
11/21/2017 2:49:13 AM • Delta Model 470:... • Answered on Nov 21, 2017
My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
10/23/2017 9:28:34 PM • Delta Model 470:... • Answered on Oct 23, 2017
My Delta kitchen faucet is putting out small black particles with the hot water. What can I do to stop it?
Is the kitchen faucet the only problem? If not, then the water heater or other problem may exist in the water system.When you run the hot water, are the particles always coming out or do they go away after while?Black particles can be caused by carbon water filters. Do you have a filter? Those particles stop over time. Washers and "O" rings that are wearing out can cause black particles. I would check under the sink to see if you have any slow drips. You may see white, green or black colors along the fittings.I've also seen black particles from algae in the line. Maybe there's a leak somewhere in the system that dripping and cause the algae to form? Inspect your water lines and checking for leaks anywhere in the system may help. If you turn off all your faucets, washer, hose bibs and check the water meter, is it still moving? I'd check it every 15 minutes for an hour to see if there is a slow leak.Here's a diagram that shows all the parts: PlumbingWarehouse com Delta Kitchen Faucet Parts For Model 470 472I'd also take out the aerator and see if it's clogged. You may have to change the washers and "O" rings.Parts and prices: (sample list)https://www.plumbingsupply.com/deltakitchenfaucets.html
12/20/2016 2:56:27 AM • Delta Model 470:... • Answered on Dec 20, 2016
Sticking of KWC DOMO model faucet.
Just received the new part for the domo. My model is older and is chrome with black. I have removed the top screw and need to know what is the next step in taking apart the rest of the faucet so I can replace the new part # k.32.60.00
Thank you, Stuart
5/25/2015 3:35:38 PM • Delta Model 470:... • Answered on May 25, 2015
How do I remove the hub on the faucet to get to the o rings
There is a set screw under a removable button cover on the handle. Remove screw to disassemble and access cartridge. See link. http://www.deltafaucet.com/media/MandI/76075%20Rev%20B.pdf
2/22/2015 5:38:27 PM • Delta Model 470:... • Answered on Feb 22, 2015
Leaking from the flexy hose to the sprayer
You must change hose. The part is probable available on Amazon
11/6/2013 8:01:54 AM • Delta Model 470:... • Answered on Nov 06, 2013
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
11/6/2013 7:57:11 AM • Delta Model 470:... • Answered on Nov 06, 2013
Leaking kitchen facet by delta
Great design! Even I think that it's a must have kitchen appliance specially for modular kitchen users.
9/12/2013 1:24:38 PM • Delta Model 470:... • Answered on Sep 12, 2013
How to fix a leaking faucet
want to extend my delta tap about 5inches how do i do it?
9/11/2012 3:44:47 PM • Delta Model 470:... • Answered on Sep 11, 2012
In our Delta signature 470
The only way to stop the leak where you push the button is to replace the wand/head. Delta has a lifetime warranty on there faucets. Call Delta at 1-800-345-DELTA (3358). Give them your model # and they will send you the head for free.
9/9/2011 12:15:20 PM • Delta Model 470:... • Answered on Sep 09, 2011
Kitchen Faucet 470 WH installed
You need to replace the springs and seats...
Here is the kit you need...
http://www.bing.com/shopping/faucet-delta-parts-rp4993/where-to-buy/1C8A5B4DF3AE2B6FBEE4?q=delta+faucet+kit&FORM=HURE
Take the handle off.. there is a set screw under the handle...
Then turn the top off...
Take out the ball... observe the position of it...
Then use a very small screw driver to remove the old springs and seats and install new ones...
then replace the ball, top and handle...
heatman101
3/28/2011 5:25:12 PM • Delta Model 470:... • Answered on Mar 28, 2011
Faucet does not completely shut off when properly
This problem exists when the seats get wore a and there is no resistance to shut water off. Replace the seats and springs to correct this problem. Shut water off and remove handle with a allen wrench and retaining collar to expose the valve body to gain access. Once apart remove seats and springs and reassemble and problem should go away.
3/12/2011 7:28:02 AM • Delta Model 470:... • Answered on Mar 12, 2011
How can I remove wand
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
2/10/2011 8:14:10 PM • Delta Model 470:... • Answered on Feb 10, 2011
Handle cannot move to the hot water position
You need to buy the internal replacement kit.
The seal has jambed (sliped out of place) on the hot water side.
2/2/2011 11:36:21 PM • Delta Model 470:... • Answered on Feb 02, 2011
I am trying to repair a signature series delta
you need to leave the hose go down the hole and feed it back through when your done
1/17/2011 11:00:57 PM • Delta Model 470:... • Answered on Jan 17, 2011
Delta Model 470: Signature Kitchen Pull-Down/Out Faucet - White Logo
Popular Tags
92 questions posted
Top Delta Plumbing Experts
David Shaub
john h
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Delta Plumbing
  • Delta Plumbing
Most Popular Question
in our delta signature 470
  • Plumbing
