20 Most Recent G Shock X-Large 8900 G-8900A-1 Watch - black/blue Questions & Answers
i would suspect it needs a new battery you only got it 2 month ago but the battery could av been in a couple of years..
G Shock X-Large... | Answered on Feb 13, 2013
Welcome to Fixya. Can you provide the exact make and model so taht we can send you the manual.
Thanks
Watches | Answered 2 days ago
Of course, you can. The Opus Way crash course for CLAT will completely serve you the purpose. It takes a lot of strategic approach and right planning on part of the institution as they have to design the crash course in a way that the CLAT aspirant becomes successful, even if it is his first CLAT attempt. CLAT preparation at Opus will help you gain confidence for CLAT 2018. It is one of the best law entrance coaching institutes in India whose crash course for CLAT preparation has helped thousands of law aspirants across India. Some of the key features of the crash course of Opus for CLAT preparation are- 5 Advanced Workshops, 12 Mentor Books, 35 Full-Length Mocks, 10000 + topic wise questions, 6 days per week classroom teaching, year-wise CLAT papers and their solutions, as well as unlimited backups and helpline sessions.
If the screen goes dark, tap the screen to wake up the watch.
Swipe down from the top of the screen and tap the "Settings" icon. If you don't see the icon immediately, swipe left.
Tap the system date and time to select the time setting.
Watches | Answered on Nov 26, 2020
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Take your Amadeus watch to a jeweler and observe how to open it without damage, then note the replacement battery type for future reference.
Watches | Answered on Nov 19, 2020
There's a tiny slot you need to find that you can place a very small screwdriver to pry open the back plate. Then carefully lift off the plastic holder using the screwdriver to pry up in a couple of places. The battery is held in place with a "C" clamp which you can bend back with your fingers to pop out the old battery. Then reverse the procedure.
Watches | Answered on Nov 18, 2020
https://www.google.com/search?q=Bush+Nell+neo+XS+watch+repair&rlz=1C1CHBF_enUS757US757&oq=Bush+Nell+neo+XS+watch+repair&aqs=chrome..69i57j0i22i30i457.5183j0j4&sourceid=chrome&ie=UTF-8
Request from the manufacturer/distributor
Watches | Answered on Nov 14, 2020
fixya doesn't, but a jeweler might impart that information while replacing the battery.
Watches | Answered on Nov 11, 2020
Subaqua would be a possible source.
https://www.google.com/search?q=wr30m&oq=wr30m&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 LEARNTO USE GOOGLE AND YOU MIGHT EVENTUALLY STOP ASKING US FOR HELP
Watches | Answered on Nov 08, 2020
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Watches | Answered on Nov 07, 2020
You need the watch manual. The procedure varies across watches. You might be able to locate such via the manufacturer which should be on the back. If this is a Coast Guard watch, variations are sold at https://militarybest.com/coast-guard-watches.html
Whether or not they would or could help, I don't know.
I am rather presuming your query is unrelated to the following:
https://www.watchguard.com/help/docs/help-center/en-US/Content/en-US/Wi-Fi-Cloud/manage_wirelessmanager/configuration/system/timezone_location_tag.html
My Neff Digi watch only was the mode button on the top right and a light button on the top left. I tried various different methods for setting the time and can't figure it out please HELP!!
Watches | Answered on Nov 05, 2020
Take your MK watch to a jeweler who will demonstrate the correct way to open it, identify the battery type, and replace it.
Watches | Answered on Nov 02, 2020
Contact Time Track Services directly and explain the problem to them. They will be able to help you sort another form of payment. They will also appreciate you took the time and effort to warn them.
Watches | Answered on Oct 19, 2020
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Watches | Answered on Oct 18, 2020
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Watches | Answered on Sep 27, 2020
Visit the website.. You will find the instructions
Watches | Answered on Sep 24, 2020
G Shock X-Large 8900 G-8900A-1 Watch - black/blue Logo
1 questions posted
Top G Shock Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a G Shock Watch Expert? Answer questions, earn points and help others
View Most Popular
G Shock Watches
  • G Shock Watches
Most Popular Question
died
  • Watches
