20 Most Recent
Emporio Armani AR1410 Mens Ceramica Rose Gold Black Watch Questions & Answers
Is my ARMANI AR1410 authentic
You really have to have somebody look at it. Some of us can just take the watch from your hand and tell its fake from the feel. Some knockoffs are much more convincing. Serial number could be inside the watch too. I opened a "Swiss made" watch once, and on the inside the actual watch movement said "made in China". They had used the case for the real thing but put an el cheapo movement inside!
What size battery does my Emporio Armani AR-5331 take
The size of the battery that your Emporio Armani AR-5331 watch takes will depend on the specific model of the watch. Some common sizes for watch batteries include:
- CR2032: A small, coin-shaped battery that is commonly used in small electronic devices such as watches and calculators.
- CR2025: A slightly smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
- CR2016: An even smaller version of the CR2032 battery, also commonly used in watches and small electronic devices.
It is best to refer to the user manual or contact the manufacturer to determine the correct size battery for your Emporio Armani AR-5331 watch. Using the wrong size battery can damage the watch or cause it to function improperly.
Emporio Armani Watch Chronograph AR0385 stopped.
Please replace the battery and check if the watch starts to function as usual. If not, you might use the knobs on the side of the watch to adjust the seconds hands once before taking the watch in for repair. Thank you.
Is there a video for removing back of Emporio Armani AR 0540?
I wouldn't want to risk scratching up the back of an Armani. If you have a watch repair shop near you, it's better to take it there. I've taken several down for battery replacements, etc. and it has cost between $7-20, battery included. That said, I did find a video, but it's not for the exact Armani model and they used professional tools to do it. I saw another video where you could use standard tools, but you run the risk of gauling the metal on your watch in the process.
