20 Most Recent American Standard Cambridge 5 Ft. x 32" Right-hand Drain Whirpool Tub, Whit Questions & Answers
In an ideal world you would like the drain end lowest and level from side to side. It won't hurt anything if it is not level, however the water may not all drain out if it is not level.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
American... | Answered on Oct 06, 2017
you have to access the lower control the switch should be an air type one it uses air pressure from pushing in the button they some times crack ,dislodge or damaged and will not turn on or off unit also switch can fail
American... | Answered on Jul 12, 2017
White and black. Special order any color - but it will take months to arrive.
Thanks!
American... | Answered on Aug 26, 2011
Good day,
You have the standard heating system on that model dryer.
It uses a standard thermal fuse which is a long skinny white bakelite device, with 2 wires on it and held in with one screw.
I hope we are talking about the same thing. The thermal, and all thermostats on this machine are located in various places on the back of the machine behind the rear panel.
If all else fails, remove the device you are talking about, and along with the model number you posted and take it to a local appliance parts house.
Any good appliance counterman will have the answer.
American... | Answered on Dec 14, 2009
American Standard has the Installation Guide for some of their kitchen faucets on each product's page. A list of some of their two-handle kitchen faucets is available here: https://www.americanstandard-us.com/kitchens/kitchen-faucets?No.%20of%20Handles=Two&page=1&plimit=21 . Home Depot has the Installation Guide for the Heritage wall-mount faucet with Goose Neck spout on the product page: https://www.homedepot.com/p/American-Standard-Heritage-2-Handle-Wall-Mount-Kitchen-Faucet-in-Polished-Chrome-with-Gooseneck-Spout-7293-252-002/100080273 . The current link to the guide is https://images.homedepot-static.com/catalog/pdfimages/de/deca2fce-73fc-47a2-acb5-efc7232dac17.pdf .
These are standard plumbing installation guides. They condense most of the steps of the hardware install into one diagram/step of the guide.
I hope this helps. If you need further assistance, please add more information on the style of your faucet. (Is it a wall-mounted faucet or a sink-mounted faucet?)
American... | Answered on Aug 06, 2020
Download the BILT app and search for your faucet model. The icon is turquoise with a white nut ( as in nut and bolt).
It will show you step by step nearly everything under the sun. Hope that helps a bit.
American... | Answered on Nov 09, 2019
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
American... | Answered on Dec 10, 2018
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
American... | Answered on Nov 27, 2018
mixing valve and ceramic washers are defective. American Standard is not what it used to be. Parts are substandard and imported from china. Get yourself a Glacier Bay, and contact American Standard and demand your money back or a credit.
American... | Answered on Sep 27, 2018
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
American... | Answered on Apr 13, 2018
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
American... | Answered on Jan 12, 2018
I would google it . Or look on u tube
American Standard Cambridge 5 Ft. x 32" Right-hand Drain Whirpool Tub, Whit Logo
11 questions posted
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • American Standard Plumbing
Most Popular Question
bath tubs installation
  • Plumbing
