20 Most Recent
White-Westinghouse White Westinghouse Fridge Replacement Refrigerator Ice Maker Questions & Answers
My fridge is not cooling at all but the light is still on and frezzer is still working. Help
The cold air that you receive to your refrigerator comes from your freezer, so when you normally have a problem with a refrigerator not cooling you would check the freezer first. The first thing I normally check is to see if the evaporator inside the freezer is frozen or full of ice. Some times you can actually see ice build up on the Pana in the back of your freezer. Is the fan running in the freezer? if there is no ice build and the evap. Fan is working then I would check the compressor and the condenser in the back of the fridge. Are they running? If your freezer is iced up you most likely have a defrost problem and would need to call a service tech. To find out which part is causing it. If the fan in the freezer is bad you might be able to do it yourself. If it's the compressor or condenser motor you would need to call a tech as well.
White-Westinghou...
Answered
on Mar 07, 2015
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
White-Westinghou...
Answered
on Feb 27, 2014
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
blog.us
cooler.com/
walk-in-
cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
blog.us
cooler.com/maintain-
walk-in-
cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
Refrigerators
Answered
on Jan 11, 2021
Hoshizaki ice machine
The machine will continue to run water all the time while in harvest mode. The control board blew, and just needs to be replaced. Controls boards can fry without any other signs of anything else being bad. Hoshizaki ice machines dont have a over heat relay that shuts it down upon oerheating if it is the control board
Refrigerators
Answered
on Jan 11, 2021
Water is not flowing into my GSI-23 ice maker.
As the harvest cycle (the ice maker fingers rotate to sweep the cubes out of the mold) comes near the end of the rotation, a switch in the ice maker activates to send power to the water valve (located under the refrigerator where the house water supply line connects) and allows perhaps 4 cc of water to flow up a 1/4" plastic line to a fitting on the back of the refrigerator that is aligned with the ice maker inside which then flows into the maker mold. That process refills the ice maker mold and everything shuts off to freeze this water and then initiate another harvest cycle when the entire process is repeated. If there is no water, then there is no ice. Focus on why the water isn't flowing all the way to the ice maker. Look for an ice blockage in the tubing that comes from the back, inside wall of the freezer to the ice maker, or a bad valve. It is rare, but the switch inside the ice maker could be bad. The water valve or a blocked water line are most likely the culprits. Another trick is to pour water into the ice maker mold, wait several hours and see if that freezes and ejects into the pan. If so the ice maker is working, it just has no water to freeze.
Refrigerators
Answered
on Jan 09, 2021
Capillary tube replacement
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Refrigerators
Answered
on Jan 09, 2021
