20 Most Recent Logitech LX6 Mouse Questions & Answers
1. Restart the computer.
2. If the mouse still fails to work, unplug it and connect the USB connector to a different slot.
3. Check the batteries / Charge the batteries / Try new batteries.
4. Re-install the drivers from here: http://www.logitech.com/en-us/428/3879?section=downloads&WT.ac=sc'downloads''dd
Logitech LX6... | Answered on Mar 02, 2011
Plug the wireless reciever into a different USB port.
open mouse folder inside control panel and check everything in all tabs.... definitely you have to work with keyboard to reach there , use tab and alt buttons to choose option,to check in acheckbox you have to press the alphabet which is underlined in a sentence near checkbox.
Logitech LX6... | Answered on Apr 24, 2010
I just wanted to say Guru's probably right. I had this same problem and realized my cell phone was right between it. Moved the transmitter a little closer, moved my phone, and it works like a charm.
Logitech LX6... | Answered on Apr 14, 2010
There are a total four small phillips screws on the base of the mouse. Two are in the battery compartment, while the remaining two screws are located beneath two self-adhesive teflon pads at the front of the mouse. Simply remove these pads with a small flat screwdirver or scraper in order to reveal the screws underneath.
Logitech LX6... | Answered on Apr 13, 2010
go to device manager and select your mouse and then go to its properties and in  power manageent tab and UNCHECK allow computer to put this to sleep somethin like this
Logitech LX6... | Answered on May 19, 2009
Make sure you have setpoint installed, and you can configure the buttons.
For left to right the default is to press the wheel left to right, for zoom I think it is hold press down on wheel and scroll.
You can easily set these things in setpoint follow the link below to download the latest version
Download Setpoint
Logitech LX6... | Answered on Mar 23, 2009
Hi
contact your dealer to replace the mouse it sounds faulty if you have fixed the problem do share how you solved it.
Logitech LX6... | Answered on Dec 28, 2008
ALL-IN-ONE CONTENT CREATION Start recording high-quality video content the second you plug in your new webcam with Logitech Capture. Capture enables you to customize your recording, adjust your camera settings, and even create vertical video in one intuitive interface.
Download the software from given link to record the videos.
https://download01.logi.com/web/ftp/pub/techsupport/capture/Capture_1.10.110.exe
Logitech... | Answered Yesterday
Logitech is a maker of many periphery devices including keyboards, speakers and mice. Always include full
make model (what it is)
Then a GOOD description of what is wrong and what you have tried.
Logitech... | Answered on Dec 27, 2019
just yours. at home are you./
to test wifi try other devices.
cell phones
PC
TV
if all fail you wifi router is messed up.
if ethernet wired, fails too,then you ISP service is bad, call them.
Logitech... | Answered on Dec 06, 2019
I use a Optical Trackman from Logitech and have foound that the contacts on the left click get dirty and won't work right or work partially. Especially frustrating when trying to highlight or shoot on FPS games. I took mine apart, just the housing , the electrics stay , and cleaned as well as I could , then blow it out with canned air. Got mine working again. My guess would be dirt or that button is worn out. Logitech has discontinued many of the Trackballs so a replacement may not be possible
Logitech... | Answered on Dec 04, 2019
Probably your new keyboard is defective.
Logitech... | Answered on Sep 27, 2019
Most likely it's a programming thing but it could be you have a loose wire... Never no.. Mite try getting a cheap pair try to see if the same problem occurs.. Thanks good luck
Logitech... | Answered on Sep 10, 2019
at Logitech.com
no keyboard model stated so generic answered.
all wireless kbd need a battery , to transmit the radio signals for BT or wifi or for custom kby tech.
pair to what, no PC stated. we can not guess what you have there. at all.
Logitech... | Answered on Jun 30, 2019
Logitech LX6 Mouse Logo
Popular Tags
15 questions posted
Top Logitech Computers & Internet Experts
Ekse
Alun Cox
Robert Stout
Robert Stout
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Computers & Internet
Most Popular Question
mouse works but flaky mouse icon
  • Computers & Internet
