20 Most Recent Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch Questions & Answers
some bands have pressure pins holding them together and once the come apart wont hold again. take it to a jewelry store with a lazer welder and they should be able to drill out the old on and weld a piece of steel
Tag Heuer Link... | Answered on Oct 10, 2009
You should go to shop. If that pin is not 24K gold they may give you one for free. Or scavenge a cheap watch for the part you need.
Hope it helps.
Tag Heuer Link... | Answered on Sep 13, 2009
I think the problem is with the running wheel inside it.Please dont try to open it and repair it yourselves.Please take it to the nearest authorised service center and they will fix your problem or replace your watch free of cost if it covers the warranty.If you have any further doubts regarding your watch please visit(http://ww2.tagheuer.com/_documents/manuals/EI2241_en.pdf).Hope you are satisfied..
Tag Heuer Link... | Answered on Jul 04, 2009
Please make sure that you have replaced your battery properly.I suggest you t reinstall it once again.
Let me know the result
Tag Heuer Link... | Answered on Aug 28, 2008
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Tag Heuer Link... | Answered on Nov 06, 2014
    How would one know from the serial number. Numbers are easier to copy than even watches!
    Tag Heuer Link... | Answered on Oct 01, 2014
    If the second is ticking as normally it is not the battery. If the battery is low the second hand will advance only at 5 second intervals meaning for four seconds the second does not move and on the 5th second it will advance by five seconds. This is a feature unique to Tag Heuer.
    Tag Heuer Link... | Answered on Jan 01, 2014
    you need to take mechanism out to push it back on, this link will help you
    http://www.pmwf.com/Watches/Watches.htm#WatchSchool
    Tag Heuer Link... | Answered on Sep 13, 2013
    Tag Heuer Link Quartz WJ1110.BA0570 Wrist Watch Logo
    Popular Tags
    10 questions posted
    Top Tag Heuer Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
    View Most Popular
    Link Tag Heuer
    • Link Tag Heuer
    Most Popular Question
    chrono hands
    • Watches
