20 Most Recent
General Electric GE Profile Harmony 4.5 cu. ft. DOE Capacity Topload Washer Questions & Answers
General Electric portable washing machine.
Question edited for clarity.
Better known as 'space saving' washing machines, they are a compromise at best.
Try presoaking the clothes overnight. Do longer programs. Try changing detergents. Wash twice.
General electric Washer gtup270em0ww
Pumping out or leaking out?
There are various rubber connectors underneath and they can perish and leak. There is a trick. slide a piece of paper under it. Switch on and after a minute, pull the paper out. It will give you a rough idea where the leak is, front, back, left or right. Then pull the machine out, and tilt it safely against the wall, get someone to hold it and look with a flashlight for the area where the wet patch on the paper was.
Parts
https://www.google.com/search?q=ge+gtup270em1ww+parts
I have a GE Adoration WHDRE526E1WW top load
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
G.E. dryer DHDVH52EFOWW shutting off in middle of
If you try to start it as soon as it shuts off does it hum or buzz & won't start if it does you may have the motor getting hot & shutting off then when it cools down it will start again.
This is a pretty common problem. If this is the case you may have to replace motor. Also check all the vents the one going outside should blow out pretty good if not clean it out . Take the vent off the back of the dryer and see how much air is coming out be sure fan is working . May have to clean lint out around fan it can block the fan. Hope this helps Have fun
Model ge whdrr418g, i need to remove the agitator.
Hello:
You need to grab the agitator from the bottom( fingers under agitator in the tub) then kind of alternate puling up with your right and left hands.. There is no screw holding your agitator in place..it may seem like it doesn't want to let go at first but it will eventually..
Good luck
