20 Most Recent Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie Questions & Answers
You now have a 55" parts unit !!! A replacement 55" panel will most llikely cost as much as a new set !
Samsung 55"... | Answered on Jan 11, 2013
If it is anything like this one, there are three big coils on the board. The original one was made by a company to Samsung specs or made in house by them. The replacements are made in China as cheaply as they can. There doesn't look to be a lot of clearance where it is fixed. I would suggest rigging a computer fan to blow air over it.
https://www.ebay.ca/itm/Samsung-BN44-00871A-Power-Supply-Board-UN40K6250AFXZA/112637036155
Samsung... | Answered 3 days ago
My experience with a lightning struck tv suggests even if you get it working it is unlikely to be the tv you remember ever again.
Even a mild lightning strike has a great deal of power and will track across every part of the tv circuitry in an effort to find a pathway to ground.
Unlikely to be the power supply alone though the components are a little more robust than many in a tv, however it is difficult to know without the sort of tests a tv guy can provide as many modern power supplies are intelligent switch-mode types that monitor the current drawn by circuits and will shut down if it exceeds limits and sometimes won't work at all when disconnected. This is a necessary precaution against fire.
The flashing red light might be expressing a fault code - or might not.
It is a premium tv and if your home insurance wouldn't cover the cost of replacement it would be worth the cost of a repair estimate from a professional.
Samsung... | Answered on Jul 02, 2020
If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Screen-shots to defective LCD and Plasma panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Samsung... | Answered on Jul 01, 2020
Go to Smart Hub add the App or a link to the website. Register, pay, and stream.
Connect your Samsung TV to the internet
www.samsung.com > support > answer > ANS00079028
Just when you thought your Smart TV couldn't get any smarter, it turns out it can access the internet too. If you connect the TV to Wi-Fi or a wired network, you ...
Connect a Samsung TV to the Internet ' Samsung Support ...
www.samsung.com > support > tv-audio-video > connect-tv-to-internet
Jun 3, 2020 - Connect your Samsung TV to the internet to stream movies, browse the internet, and get the most out of the Smart Hub apps. It's also great to ...
Samsung... | Answered on Jun 30, 2020
just cause your power supply is tested good doesnt make it good it could be a shorted panel or more likely the leds behind it unplug everything except the remote eye mainboard and buttons from the power supply and see if the light stays on if it does then i would look into the led strips also check the flash's i dont remember if samsung has a set amount of flashes = a code
Samsung... | Answered on Jun 26, 2020
Sorry, Samsung is know not to work with anything but Samsung. If it lists a code in the back of the TV's booklet for pairing you might have a chance.
Samsung... | Answered on Jun 25, 2020
I wonder what the issue is .....................
start by trying to reset your TV. Disconnect the power cord from the outlet, then press and hold the power button on the TV (not the remote), for at least 10 seconds. Then wait a few minutes and plug the TV back in and press power once. 2 blinks on Samsung TV's usually indicates a bad power supply
Samsung... | Answered on Jun 24, 2020
None of them. Your television is toasted, every IC overloaded. Claim on your house insurance or contact the electricity utility company. They will have a record of the 100,000 volt surge and will replace the set.
Samsung... | Answered on Jun 23, 2020
https://www.samsung.com/nz/support/tv-audio-video/troubleshooting-sound-issues-on-your-samsung-tv/
Samsung 55" UA55C7000 MULTISYSTEM LED 3D TV FOR 110-220 VOLTS 2 pairs of glasses and a movie Logo
Popular Tags
2 questions posted
Muntejaya Ginting
Muntejaya Ginting
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
broken screen
  • Televison & Video
