20 Most Recent Easy N388 Watch Phone Tri Band Single SIM with Touch Screen Bluetooth Questions & Answers
2answers
How can this invalid sim issue be fixed?
Invalid sim means the sim card may no longer be active , faulty or the device is network locked , cheapest option is replace the card if still not functioning the issue is with the device , giffgaff will not use the same APN as O2 , that may have to be manually input
1/4/2015 4:43:04 PM • Easy N388 Watch... • Answered on Jan 04, 2015
4answers
HOW TO GET A PIN CODE IN RAN ONLINE PH
how to retrieve my pin code in ran online
4/23/2024 5:38:00 AM • Cell Phones • Answered 15 hours ago
2answers
What is the difference between CEH V8 and CEH V9?
The difference between EC-Council's Certified Ethical Hacker v8 and the new Certified Ethical Hacker v9 is not the exam format, but the content itself. People seem to assume that since EC-Council updated the certification, the exam must be brand new. This isn't the case. In order to obtain the new CEH v9 certification, you do not need to study for and pass a brand new exam with new objectives and format. The test has the same format, is identical in size, and has the same amount of questions. There are only two things that changed. CEH V9 EXAM FORMAT AND BREAKDOWN The aforementioned v9 exam follows the same format and percentage breakdown of questions as v8. For example, the section on security will still take up 25% of the exam, while the section on tools, systems and programs will take up 32% of the exam. The full breakdown of the exam is visible on our . The Exam Details are as follows:125 questionsTo pass you need a score of 70%Maximum of a 4 hour durationMultiple choice formatHOW TO PASS YOUR CEH EXAM If you are studying v8 exam materials, you are not automatically going to fail the v9 exam. The test is updated, not revamped. This means there might be a handful of questions you may not necessarily have studied in depth for, but if you studied at all, you will have some familiarity with the new questions. The new questions are not on brand new material, they are more in-depth questions on topics that have become more relevant in the cyber security world over the last eighteen months. So you can still pass v9 studying v8 material.Should I still take CEH v8 Exam? However, if you study v8 materials you can still take the v8 exam. EC-Council has not retired the exam yet. So if you are not comfortable with the idea of taking an exam that you may not know 10-15 "new" questions, then don't. The only problem with this is that once the v8 certification does retire you will eventually need to take v9. Why prolong the inevitable then?Will I need to take the CEH v9 exam? If yes, then when? The test is updated on a rolling basis. This means that occasionally EC-Council adds new questions to the exam without updating the entire certification. The fact that v9 is now available means that there are new and updated CEHv9 study materials with a new focal point to deal with the always progressing world of IT.THE DIFFERENCE BETWEEN CEH V8 AND V9 With the update to the courseware, the exam covers certain questions differently. These questions focus on topics that are becoming more prevalent in the world of cyber security and IT. The key differences are:V9 focuses on cloud computing more than v8 did and dives into best security practices for dealing with cloud computing attacks.V9 covers mobile security and tablet computers and you must understand how to perform hacking techniques on these devices.v9 addresses new vulnerabilities in cyber security such as, Heartbleed, Shellshock, and POODLE. CEH v9 vs v8 What New on the Certification Exam TechRoots
4/22/2024 6:43:13 AM • Cell Phones • Answered Yesterday
I'd like to update my stereo in my Citreon C3 (2007) to a double din header unit.
Let's explore your options: Double DIN Stereo Upgrade Kits: There are aftermarket double DIN stereo upgrade kits available specifically for Citroen C3 (2010-2016) and Citroen DS3 (2010-2019) models. These kits include everything you need for a seamless installation, including a fascia kit, plastic brackets, screws, blanking buttons, steering wheel control interface, antenna adapter, USB and AUX retention leads, and a universal patch lead. The installation process involves removing the original single DIN radio, fitting the new plastic frame and fascia around the double DIN radio, and connecting the wiring harness and other components. These kits are designed to retain steering wheel audio controls and other features. Keep in mind that dashboard modifications are required, so professional installation is recommended. Connects2 Adapters: If you choose an aftermarket stereo that isn't specifically designed for your Citroen C3, you can use a Connects2-style adapter to convert a compatible aftermarket stereo to control the screen above the radio (date/time, etc.) 3. This way, you can still access essential information. For example, a Double DIN Android Auto-compatible stereo like the JVC KW-M560BT could fit in the space after removing the cubby and factory radio. Some C3 models have a dash-mounted CD autochanger or other features that need careful handling during the upgrade. Citroen C3 2009 Aftermarket radio upgrade - Double DIN (citroenc3owners.com) Professional Installation: Consult with a car audio installer or technician to choose the best solution for your specific Citroen C3 model. Regardless of the approach you take, professional installation is highly recommended.
4/20/2024 10:12:16 PM • Cell Phones • Answered 2 days ago
Kyocera DIGNO Dual WX04K. HOW TO RESET KYOCERA WX04K DUAL DIGNO please?
How to hard reset KYOCERA DIGNO WX04K WILLCOM
GSM Hosting https://forum.gsmhosting.com > vbb > how-hard-reset... Feb 24, 2016 - Ihave solution turn off mobile than holde both volume keys and connect usb i will install adb drivers and than install kingoroot in pc and ... Missing: DUAL ‎' Show results with: DUAL
How To Do A Hard Reset On Kyocera DIGNO Dual WX04K
Tweakdroid https://tweakdroid.com > hard-reset > kyocera-digno-d... Nov 28, 2021 - To start, go to the Settings menu of your Kyocera DIGNO Dual WX04K; Find the factory data reset option. · Click on Erase all data. ; Turn off the ... ..
4/20/2024 7:30:08 PM • Cell Phones • Answered 3 days ago
Necesito desbloquiar mi telefono.
4/18/2024 4:28:55 PM • Cell Phones • Answered on Apr 18, 2024
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue: Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists. Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery. Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process. Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues. https://www.manua.ls/stanley/bc15bs/manual If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM • Cell Phones • Answered on Apr 18, 2024
2answers
HiSense F22. I forgot my parent access code, my daughter's phone is locked.
Are you sure you aren't the daughter trying to get around the code? The onus is on your daughter to remember her access code. Your parental code allows you to make restrictions to the phone.The only way to fix it is by doing a Factory Reset. Scrub it clean and start again.https://www.google.com/search?q=hisense+f22+hard+reset..
4/18/2024 6:34:42 AM • Cell Phones • Answered on Apr 18, 2024
Plsssssssssss 546852-E0BD-A257 super need for 1.3.3
All questions need full 'make model (what it is) as first 3 words, and a clear question please. Here you go https://www.google.com/search?q=546852-E0BD-A257+super+need+for+1.3.3 ..
4/17/2024 4:56:53 PM • Cell Phones • Answered on Apr 17, 2024
Can someone please help me with network unlocking my Telstra Oppo A38?
Unlocking your Telstra Oppo A38 can be done using the International Mobile Equipment Identity (IMEI) number. Here are the steps you can follow: Check if Your Phone Is Locked: Insert a SIM card from a different provider into your phone. Allow a few minutes, then turn your phone off and back on. If the different provider's name appears in the status bar, your phone is unlocked. If it's locked, you'll receive an error message asking you to insert a valid SIM card, and you won't be able to make calls, send texts, or browse the internet. How do I unlock my phone from the Telstra network using IMEI? - Telstra https://whatphone.com.au/telstra/how-to-unlock-telstra-phone-for-free/ They must have been kidding.
4/17/2024 3:38:15 PM • Cell Phones • Answered on Apr 17, 2024
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter? Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM • Cell Phones • Answered on Apr 17, 2024
There seem to be two categories of notes on my iPad Pro. One is Notes which is going to iCloud and the other is ATT notes which is not syncing with my other devices and not going to iCloud.
You may find it more convenient to remove ATT Notpad and use the version on your icloud account.
4/16/2024 8:20:57 PM • Cell Phones • Answered on Apr 16, 2024
2answers
Fccidalsmt877t. It won't charge. How do I fix this please?
More information please. What is this number from? Is it a serial number? A model number? What company made it? That number comes up as too many things when googled to know what you need help with.
4/16/2024 6:53:28 PM • Cell Phones • Answered on Apr 16, 2024
I'm trying to call and the only find they are not in service. Where can I get a good phone number?
You would need to tell us WHO you are trying to phone George? Then we can try and find yo a good support number. ..
4/16/2024 6:41:12 PM • Cell Phones • Answered on Apr 16, 2024
How do I fix E71 on the la cimbal Q1?
You posted to the category 'Cell Phones'. This is likely a 'La Cimbali' rather an 'la cimbal' a coffee machine. This is also likely to be a Q10 rather than a Q1 which is Tamping Machine from Puq. All questions need full 'make model (what it is)' first 3 words please. Upper right of this page in the manual https://www.manualslib.com/manual/1737003/Lacimbali-Q10-New-Touch.html?page=32#manual No other clues except that Cimbali does an E71 model in Dubai. https://www.google.com/search?q=la+cimbali+e71+error ..
4/13/2024 11:15:32 PM • Cell Phones • Answered on Apr 13, 2024
2answers
I need a PUK code for total station leica TS06.
I need leca t.s 06 plus serial 1891880 puk cod
4/13/2024 2:47:17 PM • Cell Phones • Answered on Apr 13, 2024
Mine got good volume but when they talk you can barely hear them
'Make model (what it is)' in all question please first 3 words. You posted to the category 'Cell Phones' so let's assume it is a phone. When you are actually in a call use the buttons on the side of the phone to increase the volume. It is usually the upper button, and can only be done when you are on a call.
9 Ways to Improve Your Android Phone's Sound and Volume
Lifewire https://www.lifewire.com > Mobile Phones > Android Jul 12, 2023 - To make sure the volume on your phone is working properly: Turn off Do Not Disturb Mode. Along with silencing your ringer, Do Not Disturb mode ... ..
4/9/2024 4:11:16 AM • Cell Phones • Answered on Apr 09, 2024
GPX Media Player model MT851B. My touchscreen doesn't respond on it. How do I fix it
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen. You could try three things Look for a tiny Reset hole in the back. Connect it to a computer and in Windows Explorer see if the is any useful right click commands? Or leave it running until it runs out of power, wait 24 hours before recharging. ..
4/9/2024 3:30:50 AM • Cell Phones • Answered on Apr 09, 2024
What does it mean for actaris prepaid meter to write ""call" on standby screen. Is it spoilt?. Quick response pls. Thanks.
I would call your service provider as I think that is what it means. There is no error message "call", as far as I can find.
4/8/2024 5:13:35 PM • Cell Phones • Answered on Apr 08, 2024
Easy N388 Watch Phone Tri Band Single SIM with Touch Screen Bluetooth Logo
1 questions posted
Popular Products
Top Easy Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an Easy Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Easy Cell Phones
  • Easy Cell Phones
Most Popular Question
invalid sim issue fixed
  • Cell Phones
