20 Most Recent Whirlpool Gold 30 in. Electric Convection Wall Oven with Built-In Questions & Answers
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
11/24/2015 1:40:03 AM • Whirlpool Gold... • Answered on Nov 24, 2015
2answers
What is the life span for a 13 year old Whirlpool stove? I got it in 2012. It is an apartment stove.
Never ever use the Self Cleaning Feature. Its main function of to break things like elements, door looks and frazzle control boards. That keeps the maker is steady sales of spares. My old Ge Stove is from the mid 1970s. Of course they don't make them like that any more. They are non-electronic, so only elements can fail. You can check elements for continuity with a multimeter and replace them. If you fancy a new one, get one but never use the self cleaning feature and it will indeed last you 30 years. Bake elements https://www.google.com/search?q=Whirlpool+stove+bake+element ..
2/6/2024 3:53:56 AM • Whirlpool Ovens • Answered on Feb 06, 2024
I have an older Roper by Whirlpool self cleaning oven. It does not have a door lock or timer. Do I just close the door and turn the oven to clean and it will indicate when the cycle is done?
Never ever use the features of a Self Cleaning Oven. We see the damage they do here on Fixya, and the worst is the door not unlocking, and the most expensive is when they fry the mainboard. They all have a door interlock. If you were to open it when it was running, it would frizz your eyebrows!
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle... A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
11/12/2023 6:41:37 PM • Whirlpool Ovens • Answered on Nov 12, 2023
Whirlpool wall oven F1E1 error
if wiring ok possible weak ignitor
10/14/2023 4:57:24 AM • Whirlpool Ovens • Answered on Oct 14, 2023
2answers
How do i start the self cleaning cycle on my whirlpool self cleaning oven
Whirpool Self Cleaning Oven Instructions Hunker Please provide us the model number if you can.
9/2/2023 1:42:43 PM • Whirlpool Ovens • Answered on Sep 02, 2023
Whirlpool YWFE710H0BS0 oven no longer heats up.
Check the elements for continuity with a multimeter. Sometimes the connectors draw too much current and can burn out as well. Both are easy tests. A runaway temperature can make elements fail because there is no thermostatic control, they just glow bright yellow..
8/26/2023 10:38:37 AM • Whirlpool Ovens • Answered on Aug 26, 2023
2answers
Whirlpool double oven electric e1 f2 error
error f1 is shown when there is a problem in the control panel
7/23/2023 11:31:00 PM • Whirlpool Ovens • Answered on Jul 23, 2023
How do I replace a sealed bake element on Whirlpool WERP4120PS range?
Ed,Check here and watch video.https://www.repairclinic.com/ProductDetail/655475?i=178I entered your model and there's 4 diffrent ones PS1 PS2 PS3 etcso if this isn't it ck out the others on their site.Best to you.another site with video..under the part picture..https://www.appliancepartspros.com/whirlpool-elmnt-bake-wp9755770-ap6013936.htmlcopy n paste link.
7/4/2023 8:54:18 PM • Whirlpool Ovens • Answered on Jul 04, 2023
2answers
What does E1 F2 code means?
Greetings, This might indicate a bad keypad or that the cable connecting the keypad to the chip board within your whirlpool has come loose. You might need to work with whirlpool to see if they keypad needs replacing or if the internal chip board itself is faulty. Thank you.
4/24/2023 6:16:24 PM • Whirlpool Ovens • Answered on Apr 24, 2023
I Have a whirlpool gold accurate system microwave /oven combo Self cleaning and broiler is not working . Regular oven works . There are no error messages . What is causing this
The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it. On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat. Or Oven safety valve needs to be checked with multi meter ohms / voltage
3/13/2023 4:51:29 PM • Whirlpool Ovens • Answered on Mar 13, 2023
How to set the clock to not display time
the time? You can turn off the clock display from the oven's control panel. Look for a setting that says "Clock" or "Time of Day" and set it to OFF. If you don't have this option on your oven, contact the manufacturer directly and they will be able to help you.
2/23/2023 12:33:19 PM • Whirlpool Ovens • Answered on Feb 23, 2023
Whirlpool GR478LXPQ1 stove and oven top doesn't work?
To be honest, it sounds like you purchased a secondhand, faulty appliance. Although it might be loose connections due to the move, the most likely issue would be the main board and due to the price of them, that is often a good enough reason to buy a new stove. https://www.google.com/search?q=Whirlpool+gr478lxpq1+stove Error messages are normally searchable, but not that one. Take it back or call out a Whirlpool Service engineer to diagnose, fix and set it up. It is a sorry tale and not an easy one to fix. https://www.google.com/search?q=Whirlpool+gr478lxpq1+stove+AM71+UI42EEWET+107 ..
2/19/2023 2:17:18 AM • Whirlpool Ovens • Answered on Feb 19, 2023
Whirlpool oven control board
Check on ebay they have companys that sell replacemnt parts .
2/9/2023 9:55:44 PM • Whirlpool Ovens • Answered on Feb 09, 2023
Clean my oven whirlpool akz146/w h now it keep tripping electrics how can i dry or get to electrics to dry them
possible shorted ignitor replace first unplug then try if doesnt pop circuit then replace
12/23/2022 5:02:01 AM • Whirlpool Ovens • Answered on Dec 23, 2022
2answers
Whirlpool Accubake panel completely dim and comes to life when oven is warm
The capacitor on the back of the display is failing. Heat warms up the gel inside it. The capacitor can be replaced by an electronics tech or you can buy a new control board display..
12/11/2022 9:13:00 PM • Whirlpool Ovens • Answered on Dec 11, 2022
Why does my oven turn off and then turn on 5 minutes later or something like that
It sounds like a control board issue, or the power supply that feeds the control board. They are expensive so professional diagnosis and replacement is advised.
12/4/2022 2:08:28 AM • Whirlpool Ovens • Answered on Dec 04, 2022
Oven control panel temp lights too dim. How do I fix it.
Remove the display and on the back you will see a capacitor. It needs replacing.
11/26/2022 2:06:38 AM • Whirlpool Ovens • Answered on Nov 26, 2022
What is the purpose of the WLP83800 "AUTO" Oven Function?
If the button in question is on the top left of the control panel, this is for Automatic Convection Bake. This is the control panel picture, http://www.youserguide.com/wiki/Whirlpool_Use_and_Care_Guide_-_9782476-011 ; the word Convection is below the top pair of buttons with Auto to the left. Set the oven temperature to the regular setting for your food. The oven will reduce the temperature to the appropriate temperature for baking with the convection fan running. You do need to check the food more frequently. See http://www.youserguide.com/wiki/Whirlpool_Use_and_Care_Guide_-_9782476-016 . I hope this helps. Cindy Wells
9/25/2022 9:50:08 PM • Whirlpool Ovens • Answered on Sep 25, 2022
Whirlpool Gold 30 in. Electric Convection Wall Oven with Built-In Logo
2 questions posted
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Ovens
  • Whirlpool Ovens
Most Popular Question
door locked after self cleaning
  • Ovens
