20 Most Recent
KitchenAid KEMS309BSS 30" Combination Wall Oven 5.0 cu. ft. True Questions & Answers
I have the Kitchenaid Superba Convection wall oven Model KEBS207DBL1 and it won't stop beeping. Shows error code F2 e3 at times. Is there a fix?
This typically indicates an issue with the touchpad or control board. Here are some steps you can take to troubleshoot and potentially resolve the issue:
Check the Cable Connection: The error code could be due to the touchpad cable being unplugged. Ensure a proper connection between your appliance's touchpad and the control board.
Power Reset: You can try resetting the oven by turning off the fuse or circuit breaker, waiting for 1 minute, and then turning it back on. Repeated power restarts may allow the oven to reset and resolve the issue.
Replace the TouchPad or Control Board: If the connection is fine and the error code persists, the issue might be a malfunctioning touchpad or a fault on the control board. In such instances, it's recommended to replace these parts entirely. Please note that this should be done by a professional to ensure safety and correct installation.
KitchenAid Superba oven will not
the latch the hooks into the door is caught inside the slot where it locks into when in self clean,you have to move the latch,unplug it,look through the air vents or slots up above the door if you can get a screw driver in there try to move the latch or if you can get something down inside to move the latch,i used a plastic long wire tie to do this before,i slid the tie down around the metal hook part of the latch that locks into the door,and pulled it to the left and got the door to open,it got hung up in the hole and the door wouldn't open but what ever works you have to move the hook part of the latch to get the door open,you can try picking up on the door to see if you can get it open or you'll have to pull the oven out and take the top off to get at the latch,hope this helps
My Kitchen Aid Superba Oven
Hi, my name is Audrey. I am a KitchenAid employee and would appreciate the opportunity to assist you with your oven. Please send me an email through our customer service address,
[email protected] and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model and serial number, and I would be happy to try to help resolve the situation with your appliance.
My kitchen aid double oven has an error code f6e6 contact am1
Possible Solutions
Reset power to the product:
There may be a problem with the Oven Appliance Manger Control or the associated wiring.
- Power unit down by turning off the circuit breaker(s) for one (1) minute.
- Power unit up by turning on the circuit breaker(s).
- Monitor the oven for one (1) minute to ensure the error code does not display again.
- Verify oven operation.
Still need help? Call or schedule service.
