It sounds like the pop up may be occurring because your Access application is not using a licensed copy or if it is licensed, it was not set up properly.
If you are the developer and you have a license for the control:
Do you see any properties that allow you to enter in some sort of license code or key? Try and compare the settings for the control with the settings for the control on the form that does not give you the popup. If you are a licensed user, then you should be able to get support from ComponentOne. There is a very similar problem to yours listed on their
forum.
If you developed this Access application and If you do not have a license user then you need to purchase a license.
www.componentone.comIf you are not the developer of this application, then you need to contact the developer about this as they are the ones with the key for the control.
Good luck. Post your results.
