20 Most Recent Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated Questions & Answers
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Bushnell BANNER... | Answered on Aug 15, 2016
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Only wipe down the exterior and blow off the lens with low pressure air then use a very good lens solution to clean them
Do not strip the scope unless you have access to nitrogen purging equipment
Bushnell BANNER... | Answered on Mar 07, 2015
Allows you to shoot in low light levels and you choose which colour you are happiest with and brightness level the same
I don't think the tube holding the cross hairs will go up that high, and shimming the front base, I don't know. What you need is a new cross hair with the dots below the cross, They will raise your line of sight past the 350 zero. Or,,,,, just put the cross at the top of your target, 600 yards without the right scope is a long shot. I hope you have a heavy barrel target rifle in 308 or bigger. My M42 is unbelievable, but, It will shoot better than me all day long and I rarely go over 200 yards. I tried the 600 yard line once, didn't like it. Oh I could hit the target, but I like hitting doorknobs at 200 yards better. What are you shooting anyway? I hope your not trying to stretch out a 223 to the max.
Bushnell BANNER... | Answered on Feb 09, 2015
You don't actually adjust cross hairs, you adjust point of impact. You do this using the turrets located near the center of the scope. the top one will adjust height, the r hand one will adjust windage.
Bushnell BANNER... | Answered on Apr 19, 2014
Check out this website. Hope it helps.
http://www.bushnell.com/products/scopes/riflescopes/instruction-manuals/
Bushnell BANNER... | Answered on Mar 18, 2014
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Bushnell BANNER... | Answered on Mar 13, 2014
i bought utg mildot 4x32 scope recently when i want to turn the control knob the green light didnt working. what shall i do?
Bushnell BANNER... | Answered on Aug 15, 2012
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Bushnell BANNER... | Answered on Sep 01, 2011
Turn it to clicks left and give it anoyher try!
Bushnell BANNER... | Answered on May 02, 2011
You need a shim to put under your scope base. Brownell's sale the kits for them.
Bushnell BANNER... | Answered on Apr 02, 2011
in short,,,throw it away? the rubber "O" rings have failed and are letting in water,,,,its had it,
Bushnell BANNER... | Answered on Nov 28, 2010
3 x 9 indicates that the minimum magnification is 3 times normal, and the maximum is 9 times normal. The last number (40) indicates a 40mm objective lens (the one furthest away from your eye). This is an indicator of the scopes ability to gather light from the environment. The larger the objective lens, the better it can gather light, and the brighter the view appears.
Bushnell BANNER... | Answered on Sep 22, 2010
The adj knobs on there are for windage on the right and elevation on the top, if they are not covered, they are turret knobs for target shooting, not for hunting. The focus knob is the rear lens, it spins in and out to fit your eyesight. It usually focus on the crosshairs and the distance for most shooters, some will not be able to get it right because of their eyes. 98% will. Hope this helps.
Bushnell BANNER... | Answered on Aug 04, 2010
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Bushnell BANNER... | Answered on Mar 24, 2010
I'd start by looking at the mounting bases.
First tighten the scope ring screws to 25 inch pounds, then loosen and remove the rings from the base(s) while still attached to the scope.
Back out the base screws one at a time, apply low strength thread locking compound and tighten each to 25 inch pounds.
Remount the rings/scope to the bases tightening till snug but not overly tight and sight-in the rifle.
Hope this helps, Mark the Gunsmith
Bushnell BANNER... | Answered on Dec 30, 2009
Bushnell BANNER RIFLE SCOPEPower: 3-9X40 / Reticle: Green/Red Illuminated Logo
35 questions posted
Top Bushnell Optics Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Marvin
Marvin
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
View Most Popular
Bushnell Optics
  • Bushnell Optics
Most Popular Question
setting 3x9x40 mean
  • Optics
