20 Most Recent
Praktica DCZ3.2S Digital Camera Questions & Answers
How to upload pictures from olympis digital camera to an acer lap top computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Lost my installation disc for
Hi lightblue,
It sad to know that you have lost your installation disc, i hope you find it.
As of now you can download the drivers from this link :-
http://bit.ly/lsfsPN Please remember to save your driver files , in a
separate folder , if possible a removable storage drive so that you can use them in the future.
Hope this helps ..:) Your feed back would be appreciated.
Luxmedia 6103 download so can get pictures from
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
How can i upload photos
Commonly there are two ways to transfer pictures from camera to PC, the first is using the USB provide it with the camera or the second is removing SD memory from the camera and insert it to a SD reader/writer connected to your PC.
If you want to use USB connection, the camera driver must be installed first or according to its user manual instructions, if you don't have installation CD, please check the manufacturer web site:
http://www.praktica.de/index.php?id=5&L=1
The display shows a padlock
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Have not got laptop with windows 7 and cannot
You do not need Windows 7 - any functioning windows PC or Mac that can accept a USB cable should be able to see your camera's memory folders. Put the camera on and 1- On a PC they appear at Start/My computer/ and in a folder somewhere within E: or D: click on folders within folders to find and copy your photo folder manually. and paste it on your computer hard drive.
2.
On a Mac it appears on the desktop.
Try to download and use picasa to import photos.
Switches off when in record mode
Hi Patrick,
That happens to mine when the batteries are getting low. More so when the flash is on auto.
Try disengaging the flash and see what happens. If it works, replace the batteries.
Best regards,
Mike
Photo transfer from memory card to acer one laptop
hey! u r stuck to such a simple problem. well not to worry when i'm here.
first of all u check whether ur card is locked??? Check the sides of the card and u will find a small slider, slide it down and then insert into ur card reader.
then open My computer, there u will find written removable drive beside the cd drive or so. open it and u will find ur photos. then single right click on any of the photo, a pop-up menu will appear, select to 'copy' option and then open the drive where u want to paste ur photo, and there again single right click and select 'paste'. and guess what ??? it's done!
hey dude, never forget to rate me!!!!
Trying download from camera to memory card
Dear Willo2,
You can not download pictures to your card. YOu can copy them with your computer. Just plug your card in to your printer, plug your camera into your computer and copy the DCIM file from your 100_**** (where **** means your camera name, ex:100_fuji.
Yours Sincerely,
Dakota Ekman
I can ´t to transfer my photos at my pc, i haven´t a cd istalation
heyii u get its software manual installed in ur computer..or if not available with u then i guess some other pc suite of the same series would also work.. else open up the menu of ur cam and change the USB settings to 'mass storage',then it will work as a card reader for you and you can access all the data inside..
and then you can just copy and paste your images..
belated merry x-mas and happy new year :)
Transfering from camera to computer
heyii if you do not have any kind of cable with it then you can go to some electronic shoppe and get a card reader for your camera's memory card..
