20 Most Recent Pentax Optio S10 Digital Camera Questions & Answers
I have had an Pentax Optio S10 auto focus camera
The only thing you can do is send it in for repair or replace it.
5/26/2017 9:43:42 PM • Pentax Optio S10... • Answered on May 26, 2017
I have a pentax optio s10,lost ma ual but can,t figure out how to transfer pics from camera memory to sd card in camera, HELP!!!
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos You may view the manual at Pentax Optio Optio S10 Operating Manual "Copying files" begins on page 164.
11/22/2014 8:22:10 PM • Pentax Optio S10... • Answered on Nov 22, 2014
0answers
0answers
Pentax optio s10 LCD monitor will not stay on
check the power saving mode in ur camera.
2/12/2013 7:24:19 AM • Pentax Optio S10... • Answered on Feb 12, 2013
Horizontal lines when i take photos with an s10 pentax camera and its on green mode
Check the ccd can be faulty
10/2/2012 6:04:22 AM • Pentax Optio S10... • Answered on Oct 02, 2012
Pentax S10 video download
ALTERNATE WAY TO TRANSFER VIDEOS AND PHOTOS TO COMPUTERIf your videos and photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
8/30/2012 4:19:05 PM • Pentax Optio S10... • Answered on Aug 30, 2012
Pentax camera screen is black will not take a picture.
Turn on the camera on and press the DISPLAY button and see the result.
8/5/2012 12:09:29 PM • Pentax Optio S10... • Answered on Aug 05, 2012
How do i cancel green mode
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode
5/22/2012 7:34:52 PM • Pentax Optio S10... • Answered on May 22, 2012
Instruction manual for Pentax optio S10 camera
Hi, You can find and download the manual on this site or link http://www.pdfasal.com/cameras/pentax-optio-s10-digital-camera-operating-manual.html- click on the Download link- tick the Check In box and supply the codes then hit Download button
10/14/2011 3:05:36 PM • Pentax Optio S10... • Answered on Oct 14, 2011
I need an instructional book
You can download the manual from the manufacturer's web site at
http://www.pentaximaging.com/files/manual/Optio%20550_IB.pdf
9/16/2011 11:35:15 PM • Pentax Optio S10... • Answered on Sep 16, 2011
Our camera Optio V10 never
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery after checking or formatting the card , make sure you transfer all the images to the PC.
Now it is possible that the control system has errors and so does no load the program as desired.
Keep offf battery for few hours while pressing down the start and menu buttons.
If not there are errors in the servo and unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
9/2/2011 10:25:48 AM • Pentax Optio S10... • Answered on Sep 02, 2011
When i take pictures on
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
7/4/2011 11:12:03 PM • Pentax Optio S10... • Answered on Jul 04, 2011
Pentax Optio S10 Digital Camera Logo
55 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
pentax s10 video download
  • Cameras
