20 Most Recent Kodak EASYSHARE V1273 Digital Camera Questions & Answers
The lens will not retract
there is a broken part inside the lens. This is pretty complex to replace so my suggestion is to buy a used one off of eBay. sometimes you can find the same model camera on tehre with a broken lcd display and pick it up really cheap
11/16/2011 3:21:51 PM • Kodak EASYSHARE... • Answered on Nov 16, 2011
The lens on my Kodak
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
8/27/2011 6:26:06 AM • Kodak EASYSHARE... • Answered on Aug 27, 2011
Lens on the camera will
heatman101==-=-=-
8/26/2011 3:04:32 AM • Kodak EASYSHARE... • Answered on Aug 26, 2011
Hi My kodak camera will not
Hi Nicola,
Maybe the battery you have is defective. Try using a new battery and see if this helps.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
7/1/2011 6:55:45 PM • Kodak EASYSHARE... • Answered on Jul 01, 2011
I have several Kodak V1273
Hi and Welcome to FixYa- I have had the very same issue with my Z Series camera. What I did to solve this: 1) Purchase a can of compressed air from any computer/office supply store 2) Prior to turning the camera on again, blow the compressed air around the lens opening (not the lens itself) where it extracts or sticks out from the camera. Blow the air in short bursts only, as prolonged bursts will turn the can freezing cold and impossible to hold after only a few seconds. 3) Try and turn the camera on again. If this succeeded, you are done! If not, read on....
4) This might sound crazy, but it worked for me: Hold the camera in one hand, with the lens side out and farthest from your palm. 5) "Smack" the camera, gently but firmly against your other hand (This might take 2 or 3 tries). This process will do one of two things: it will dislodge any large pieces of sand, dirt or general 'muck' that keeps the lens from extending when you power it on. It will also re-engage the zoom mechanism.
Good luck and let us know how it works.
5/3/2011 10:43:19 PM • Kodak EASYSHARE... • Answered on May 03, 2011
Kodak v1273 camera powers on but will not respond
my camera kodak v1273 digital flash botton is not move i thing its lock
1/3/2011 6:18:21 AM • Kodak EASYSHARE... • Answered on Jan 03, 2011
My camera has been working beautifully then about
My kodaxs v1273 started work fine then as the mouths go on, i try to trun it on but it just tells me that the date needs resting so when i go to press the reste button it auto trues off, what up with that?
11/9/2010 10:24:40 PM • Kodak EASYSHARE... • Answered on Nov 09, 2010
Won't turn on.
i have the same problem
i complained to the kodak support team via official site and even got an automatic response that it was registed..but they are deliberately ignoring me
i'm sure there are hundreds of v1273 customers out there who have the same problem...kodak doesn't seem to give a rat's ***
also, i requested a firmware upgrade....perhaps that would fix all the bugs....what can i say...that's what i deserve for taking a chance and buying kodak and not canon.
11/6/2010 7:45:13 AM • Kodak EASYSHARE... • Answered on Nov 06, 2010
What to do when zoom lens is stuck in open & camera will not work
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
6/12/2010 2:37:48 PM • Kodak EASYSHARE... • Answered on Jun 12, 2010
I dropped my camera and now it won't turn on and
Truly speaking, get it serviced. It seems that due to **** your battery mechanism has stop working.
4/30/2010 6:23:33 AM • Kodak EASYSHARE... • Answered on Apr 30, 2010
Hi, got a problem with my camera, as soon as I
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
12/23/2009 3:55:29 PM • Kodak EASYSHARE... • Answered on Dec 23, 2009
How do i change the language and set the correct time and date
Way to misrepresent yourselves
What a bunch of ****.
2/17/2009 4:11:58 PM • Kodak EASYSHARE... • Answered on Feb 17, 2009
Not So-Easyshare
I had this same problem too.... So i understand what you are talking about. Try loading the CD that came with the camera. It worked for me. Then if that doesn't work, try opening the file using another system.
12/28/2008 1:30:19 AM • Kodak EASYSHARE... • Answered on Dec 28, 2008
3answers
.MOV from Kodak M893 IS camera are not recognized by Quicktime
The codec on mac does not recognise your file....try using a different player....vlc....gom player...mx player...instead of the one iTunes insist on chaining everyone to.
4/24/2022 3:27:18 AM • Kodak EasyShare... • Answered on Apr 24, 2022
Manual for easyshare camera c1450
You may download the user guide at http://www.fixya.com/support/r13011856-lens_error and the extended user guide at http://www.fixya.com/support/r13011856-lens_error
8/1/2018 7:25:03 PM • Kodak EasyShare... • Answered on Aug 01, 2018
0answers
Kodak EASYSHARE V1273 Digital Camera Logo
19 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
several kodak v1273
  • Cameras
