20 Most Recent
Samsung Digimax S73 Digital Camera Questions & Answers
When i plug the usb
Consider NOT using a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
I need download drivers for
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Where can i download cd
You don't need any additional software to use the camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery on a Windows machine or iPhoto on a Mac.
I need software to download
Need c.d. to s73 for importing photos. will purch
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
my samsung S630
This is likely happening because your cam's memory card is corrupted. This is common with SD memory that has been used extensively for a long time and it's likely not caused by any fault in the camera.
You can try formatting the card but this isn't likely to work really. You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk. Good luck. Hope that helped.
Vivitar vivicam 3835.when i try to take a photo
SD and SDHC cards have a slide switch along one edge. The switch needs to be closest to the contacts to enable writing. If it's already there, slide it fully the other way and then back. If this doesn't work, try a different card. If that doesn't work, there may be a problem with the mechanism within the camera.
Wont take a pic and it hasd a flashing red eye
Hi kv,
Normally that would indicate the flash capacitor building enough of a charge to trigger. If the batteries are getting low, this can take a while. The camera may even shut itself off.
Make sure you have good fresh batteries in your camera.
As an alternative, try turning off the flash completely and trying it. That will either confirm it, or make me look like an idiot.
Best regards
Mike
Lens not extending
You have a lens problem. Sure it can be fixed but be sure to get an estimate first.
Card locked
Are you able to format the card in the camera. Also the USB cable you probably need is the same as most other mini USB devices.
