20 Most Recent UTStarcom CDM-105 Cellular Phone Questions & Answers
not all cell phones have a sim depends on the service provider.
UTStarcom... | Answered on Oct 17, 2017
That phone doesnt use sim cards. In the U.S., there are two different cellular technologies: CDMA and GSM (most of the rest of the world uses GSM). Up until 4G-LTE came along, CDMA phones didnt use sim cards. The cdm7176 is an older CDMA phone and thus doesn't have a sim slot.
UTStarcom Cell... | Answered on Oct 17, 2017
Depends on the phone but most likely it's under the battery. If not there, then look for a slot on the side of the phone, covered with either a small rectangular piece of rubber or an easily removed piece of hard plastic.
That being said, some models won't have a sim card. It depends on the carrier and the phone. Sprint, Verizon, & others that use their networks (such as Virgin) only started using sim cards when 4G LTE was launched. If the phone isnt designed for LTE and the phone is a CDMA phone (the technology that Sprint & Verizon use) then it wont have a sim card unless it the phone was also designed for use abroad (E.g. Europe).
Have you tried *#06# and then "Ok" or "Call" or simply type in *#06# on the main menu (on the screen as you type numbers). If this isn't helpful, then it must be written somewhere inside the battery compartment. Turn off the phone and look inside the compartment where the model number is written.
If you need further help, let me know with the model name.
Good luck.
Thanks for using FixYa.
UTStarcom Cell... | Answered on Dec 24, 2013
Probably a bad cable. Try different cable. If still no results remove battery from the phone 5 minutes then re install, power up the phone and try again.
UTStarcom Cell... | Answered on Nov 02, 2013
Do you mean the network unlock code?You can approach Classicunlocking.com and get the respective unlock code for your UTStarcom cell phone.You need to specify the mobile model,country,locked network and based on the availability get the unlock code along with free unlock instructions.
UTStarcom Cell... | Answered on Sep 13, 2013
what is mobile model? if it is UTStarcom GTX750R you can get it unlocked through codes from Onlinegsmunlock.com
UTStarcom Cell... | Answered on Feb 16, 2012
You can get the Unlock code from service provider and Unlock it.
UTStarcom Cell... | Answered on Jan 17, 2012
Your cell phone keeps track of every call you make and receive through it, including a caller's phone number and the date and time a call took place. If you answered the call, it records how long you talked. If you do not want this type of information about your habits to remain on your phone, you can delete records of individual cell phone calls received, dialed or missed, or delete the entire call log at once.
Delete Call Log
1.From the home screen, click the "Menu" button on your phone to navigate to the main menu of your cell phone. This is where your call log application is located, among other features such as your address book and text messaging.
2.Click on the "Call Log" or "Recent Calls" icon. The name may vary slightly depending on your cell phone provider.
3.Select " All Calls" from the call log screen.
4.Scroll down and select "Delete All." This will delete all calls from your call log.
UTStarcom Cell... | Answered on Sep 09, 2011
try taking your battery sim and memory cards out wait a few minutes and replace turn off the phone first, you might also try your provider and they will run through the sequence , if you have your manual you should be able to go through it blind, hope this helps good luck,regards terry
UTStarcom Cell... | Answered on May 17, 2011
Put a microSD memory card (limit 4GB) in the phone. Take a few pictures and make a short video .Use the phone menu to transfer the pictures an video to the external memory card. Use the media player to watch your recorded video. Try to play music and you will get a no content found message. Now, turn off the phone, remove the memory card and place it into an adapter that will connect to a computer by usb port. Windows should recognize it as a removable drive. If you look at that drive in Explorer you will see 3 folders. Pictures are in my_pix. Videos are in my_flix. Transfer .mp3 files to the my_music folder. When you put the card back into the phone you can play the mp3 files with the media player. Yes, I did this and it works.
UTStarcom Cell... | Answered on Jan 08, 2011
It may be a problem with service provider or singnal strength.This may lead to server time out and you lost the link.
Another chance is regarding your phone settings.Contact the customer care and set correct Wap,Internet settings
UTStarcom Cell... | Answered on Jan 01, 2011
UTStarcom CDM-105 Cellular Phone Logo
3 questions posted
Top UTStarcom Cell Phones Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tafi Nami
Tafi Nami
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • UTStarcom Cell Phones
Most Popular Question
removed battery but cannot find sim card
  • Cell Phones
