20 Most Recent UTStarcom CDM8630 Cellular Phone Questions & Answers
go to phone options then security ad irt is n there
UTStarcom... | Answered on Aug 09, 2013
call to ur networks customer care and ask them ur last voicemail calls number... simple
UTStarcom... | Answered on Apr 11, 2010
That phone doesnt use sim cards. In the U.S., there are two different cellular technologies: CDMA and GSM (most of the rest of the world uses GSM). Up until 4G-LTE came along, CDMA phones didnt use sim cards. The cdm7176 is an older CDMA phone and thus doesn't have a sim slot.
UTStarcom Cell... | Answered on Oct 17, 2017
Depends on the phone but most likely it's under the battery. If not there, then look for a slot on the side of the phone, covered with either a small rectangular piece of rubber or an easily removed piece of hard plastic.
That being said, some models won't have a sim card. It depends on the carrier and the phone. Sprint, Verizon, & others that use their networks (such as Virgin) only started using sim cards when 4G LTE was launched. If the phone isnt designed for LTE and the phone is a CDMA phone (the technology that Sprint & Verizon use) then it wont have a sim card unless it the phone was also designed for use abroad (E.g. Europe).
Have you tried *#06# and then "Ok" or "Call" or simply type in *#06# on the main menu (on the screen as you type numbers). If this isn't helpful, then it must be written somewhere inside the battery compartment. Turn off the phone and look inside the compartment where the model number is written.
If you need further help, let me know with the model name.
Good luck.
Thanks for using FixYa.
UTStarcom Cell... | Answered on Dec 24, 2013
Probably a bad cable. Try different cable. If still no results remove battery from the phone 5 minutes then re install, power up the phone and try again.
UTStarcom Cell... | Answered on Nov 02, 2013
Do you mean the network unlock code?You can approach Classicunlocking.com and get the respective unlock code for your UTStarcom cell phone.You need to specify the mobile model,country,locked network and based on the availability get the unlock code along with free unlock instructions.
UTStarcom Cell... | Answered on Sep 13, 2013
what is mobile model? if it is UTStarcom GTX750R you can get it unlocked through codes from Onlinegsmunlock.com
UTStarcom Cell... | Answered on Feb 16, 2012
UTStarcom CDM8630 Cellular Phone Logo
11 questions posted
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • UTStarcom Cell Phones
Most Popular Question
received voicemail from unknown caller
  • Cell Phones
