20 Most Recent Wells F-49 21148 Deep Fryer Questions & Answers
Hi there.
If overheating trips the hi limit and as you said, the thermostat is new, the first thing to consider is the wiring connection or is it properly wired?
You can download Owner's Manual for your fryer containing wiring diagram which you can use as reference at http://www.wellsbloomfield.com/wellsmanuals.aspx/
Regards.
Wells F-49 21148... | Answered on Jul 09, 2011
You can download Owner's Manual which contains Wiring Diagram at http://www.wellsbloomfield.com
Regards.
Wells F-49 21148... | Answered on Jun 18, 2011
Hello. Here is a wiring diagram for your unit:
http://www.wells-mfg.com/~WELLS/WELLS%20LIBRARY/Wells%20Wir%20Diag/307298.pdf
Check to see that the thermostat clicks at or about just above on, try again the reset, sometimes it is hard to push in all the way. If that does not correct the problem, make sure your power is on, do any indicators light? It could be as simple as a burnt of wire, you will need to check the resistance of the parts to tell any more, thermostat, and hi-limit should read closed (zero). The element should read 4 to 15 ohms each, there are 3 in the tube. The relay coil should be anywhere from 200 to 1200 ohms, the contacts open. I have seen broken wires in the pivot elbow where power comes up the the element head.
Hope that helped, and thank you.
If you need more help, "ask me"
Wells F-49 21148... | Answered on Apr 19, 2009
Yes it should have resistance through it unless it has been opened by a rise in temperature. Tell me what your problem is I can probably help you out.
Thanks
Wells F-49 21148... | Answered on Jul 16, 2008
The high limit switch itself is getting weak , replace it and problem solved!
Wells F-49 21148... | Answered on Sep 15, 2007
It is not economical nor even possible to convert electric fryer to gas fryer since the tank construction and parts are very different.
Wells Kitchen... | Answered on May 20, 2015
Wells Fryer manuals can be downloaded free at www.wells-bloomfield.com
Any competent service technician could cobble something like this together, but I'd challenge the insurance company, as this fryer is UL approved. Such a modification would be expensive and void the warranty and NSF and UL approveals.
Wells Kitchen... | Answered on Sep 23, 2014
Wells F-49 21148 Deep Fryer Logo
13 questions posted
Top Wells Kitchen Appliances - Others Experts
Dennis Boxerman
ray gallant
Stan Ford
Are you a Wells Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Wells Kitchen Appliances - Others
Most Popular Question
needs wiring diagram without relay limit
  • Kitchen Appliances - Others
