20 Most Recent Samsung SGH-E490 Tri-band Phone Questions & Answers
You should be able to find it on Samsung website.
If not, in past experience if you call Samsung they will send you a software disc through post
Samsung SGH-E490... | Answered on Sep 11, 2019
Gihosoft Android Data Recovery Freeware can help you do Samsung recovery breezily. With this free and powerful Samsung Data Recovery software, you can recover contacts, call history, messages, photos, videos, audios, WhatsApp and Viber messages/attachments from Samsung Galaxy S8/S8+, S7/S7 Edge, S6/S6 Edge, Note 5, J7/J5, A7/A5, etc. The operation of this program is very easy. You can view step-by-step guide here to recover data from Samsung Galaxy phones easily.
Why Choose Gihosoft to Recover Data from Samsung Galaxy?
  1. With advanced algorithm, Gihosoft can scan maximum lost data on your Samsung and recover them perfectly at minimum damage.
  2. Recover Samsung files lost due to mistake deletion, formatting, factory reset, rooting, OS update, system crash, virus attack etc.
  3. Compatible with Samsung Galaxy S8, S8+, S7, S7 Edge, S6, S6 Edge, S5, S4, S3, Note 5, Note 4, Note 3, J7, J5, A7, A5 from Android 2.0 to 7.0.
  4. Safe and reliable. Only read the deleted or lost data from your Samsung Galaxy and won't perform unauthorized behaviors such as modification, deletion etc.
  5. User-friendly. You can preview deleted files before recovery and save the data you want only to readable format like HTML for easy viewing or printing.
Samsung Recovery How to Recover Deleted Files from Samsung Galaxy
Samsung SGH-E490... | Answered on Apr 09, 2018
*2767*3855#
Samsung SGH-E490... | Answered on Apr 19, 2014
I had the exact same problem and solved it just now.
I removed the memory card from the phone and inserted in to my PC.
All of my music, videos and pics were in a folder I had created called 'mobile' on the memory card. That's what was causing the problem. The phone can open files only from specific pre-arranged folders. You can't change which folders it will search from the phone.
You have to CUT all of your files from their current folder, and PASTE them into the folders that the Samsung phone can recognize, i.e. pictures into images, mp3's into Music, etc.
My MP3 player is working brilliantly now. Hope this helps!
Rakhi
Samsung SGH-E490... | Answered on Dec 23, 2013
If your Samsung SGH-E490 phone displays an error message saying "Insert Sim card" after inserting a Sim card then your phone is probably network locked.
To unlock it,visit TheUnlockArena.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then,you can use freely any GSM network sim.
Samsung SGH-E490... | Answered on Dec 21, 2013
mark all msg and copy it to sd card
Samsung SGH-E490... | Answered on Aug 15, 2013
Unless the configuration are done it might not log on to the web. Please check your account with the service provider and see if the links are put into the phone.
Samsung SGH-E490... | Answered on Dec 30, 2011
first go to file you want to send then click on options send via bluetooth, then it will show whole files in the folder mark multiple items and send .....
Samsung SGH-E490... | Answered on Sep 28, 2011
sir please go to this url http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1903&prd_mdl_cd=GT-B5722DNUINU&prd_mdl_name=GT-B5722&srchword=GT-B5722 and download the appropriate version of PC studio for your phone, by entering the correct (model no.and type) given in the right side box.
Sir i hope my answer will help you.
Samsung SGH-E490... | Answered on Aug 19, 2011
You can unlock your phone here : http://www.unlock-zone.com/ Follow the instructions correctly to complete your task. Regards
Samsung SGH-E490... | Answered on Jul 04, 2011
The reason your phones has a constant white display is simply because there is a problem with the flex of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flex of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flex that runs through the screen to the panel, carefully detach the flex from the panel,
9. unscrew the screen of the phone, remove the flex connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
And also it might be a damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage LCD the phone will detected
Take care
Samsung SGH-E490... | Answered on Feb 19, 2011
Locate the phone settings or menu button to alter the fucntions of calls, which could be sitauted in the icons containing call waiting, call holds, caller identication features. Once at the area of functionality, find and swith beween calls.
Samsung SGH-E490... | Answered on Dec 05, 2010
You can get GPRS settings for from the service Provider,call to customer care and get Instructions from them to activate it.
Thank you,
Samsung SGH-E490... | Answered on Dec 02, 2010
Samsung SGH-E490 Tri-band Phone Logo
61 questions posted
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SGH Samsung
  • SGH Samsung
Most Popular Question
rebooting while sms
  • Cell Phones
