20 Most Recent
LG VX4500 Cellular Phone Questions & Answers
I have the cable to download pics to my computer
Hi! You may not necessarily need specific software to copy pictures from your phone to your PC.
- Using the USB cable, plug it into the phone and then plug the USB end into your computer.
- Your PC should run and automatically detect the phone and a pop-up window should open asking you what you would like to do with this new hardware.
- Your choices should be something like: "Open with Windows Explorer", "Open using Windows Media Player", "Take no Action", etc.
- Use the windows explorer options and your computer shoudl automatically open the folders contained in your phone.
- In one of the folders, you should find your pictures.
- To copy all of the pictures, click on one of the pictures then hold the CTRL key and press the "A" key on your keyboard (CTRL + A). All the pics should be highlighted now.
- Now using your mouse, copy the pics (right-click, choose copy)
- Navaigate back to your PC and find a folder to save your pictures, then right-click in that folder and choose PASTE.
- Your pics should now be saved on your PC.
If you do not receive a pop-up with actions listed (as mentioned above), then open up "My Computer" and look for the phone listed under the My Computer window. Double-click on it and the folders on your phone should open. Follow the steps above beginning at step 5. Thanks!
3/1/2011 2:59:59 PM •
LG VX4500...
Answered
on Mar 01, 2011
I have an LG VX4500 cellular phone and I have
if your provider is alltel or verizon, or any cdma carrier call *228, when the operator picks up select the number for activate. once done ur unlock code is the last 4 numbers of your phone number. If its a gsm carrer they can retrieve your unlock code for you
4/11/2009 7:59:47 AM •
LG VX4500...
Answered
on Apr 11, 2009
How come my LG Env3 only displays the Verizon logo?
There are a few possible reasons why your LG Env3 is only displaying the Verizon logo:
- The phone is stuck in a boot loop: This can happen if the phone's software becomes corrupt, causing the phone to continuously reboot and display the Verizon logo.
- The phone is stuck in a firmware update: If the phone was in the middle of a firmware update and the update failed, it may be stuck in a loop and only display the Verizon logo.
- The phone has a hardware issue: If the phone's hardware has become damaged or malfunctioning, it may only be able to display the Verizon logo.
- The phone is locked: If the phone is locked with a passcode or pattern and you've tried to enter it multiple times, it may display the Verizon logo.
If you're unable to fix the problem by yourself, the best solution would be to contact the manufacturer or the carrier to get the phone checked.
It is also possible that the phone was previously owned by someone else, it may be locked to a carrier and the only option is to contact the carrier and ask for assistance
May have blocked number how do i unblock
On the android system go to phone and recent and locate the number and select it by touching it for a couple of seconds you should get a menu that comes up and says block/unblock. If the number is not listed or block is the only option then it is not blocked
10/24/2016 10:29:40 AM •
LG VX Cell...
Answered
on Oct 24, 2016
Delete files from sim
on phone you should have a setup app, and it should tell you about your sims card, it should let you delete from there
