20 Most Recent
LG ALLTEL AX145 Cellular Phone Questions & Answers
Blocking Random Text Messages
There is a company providing service some place ... Nothing is free from the government, BTW
The only way you might get away from this is comlain to the service provider and get a new number. Then ... get her on the national do not call list immediately.
How can i switch my phone number to another phone
I believe you can keep your number, but it depends on who you're porting to rather than porting from whether the port will work or not.
Also one page says:
Some service providers have applied for a waiver from number portability which is a request for a delay or exemption from providing the ability to port numbers. If your current service provider is one such company, then unfortunately Verizon Wireless will not be able to port your number at this time.
Finally, I would suggest report them to the fcc for not releasing the line if there's any problems. I would expect delays but threatening the porting dept with an fcc complaint will make you a priority port.
I forgot my lock code
Well if you set the code then you will need to call customer care but if you never changed it then it is the last four digits to your cell phone...i just did that tonight and i finally figured it out
My cell phone is locked
If you have never set up a lock code, your code should be the last 4 digits of your phone number, or at least that was the case for my phone through alltel. Hope this helps.
My daughter quit adding minutes to her phone and it has lapsed
Depending on you network, you should be able to buy minutes, then load them onto the phone directly.
If you can't do that, you'll have to all the customer service number for your carrier and ask them to activate the phone again. (This might cause your number to change)
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
