20 Most Recent
Krell KAV-300r Receiver Questions & Answers
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output.
Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps.
Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
Help! my krell kav-300 cd
it is possible the the processor could be locked up, do to a small power surge, and if you leave it unplug for 30MIN., it should reset back to normal.
