20 Most Recent Lenovo ThinkPad T400 - Intel Centrino 2 Core 2 Duo T9400 2.53GHz Notebook Laptops (276712U) Questions & Answers
Press Fn + C. This is the key combination for Scroll Lock
Lenovo ThinkPad... | Answered on Jul 25, 2016
Should be right above F10 and says "PrtSc".
Lenovo ThinkPad... | Answered on Jul 27, 2014
A less frequent situation that can happen in a laptop resulting in it not booting up is a damaged USB port. If the pins are touching the system will not start up. You can fix this problem by using a small flat blade screw driver, tweezers or micro needle nose pliers to carefully separate and reform the contacts so they do not touch.
This is not a permanent fix because the USB port will become unusable. To fully fix it would require you to replace the system board, which may or may not be covered under your warrenty.
Lenovo ThinkPad... | Answered on Jun 02, 2013
please...change ur Home page as u want
Lenovo ThinkPad... | Answered on Mar 29, 2013
are you saying that you cant see the desktop icons on your tv? maybe you need to adjust the resoloution on the computer screen to fit the the resoloution/size on your tv. try lowering the resoloution of your computer
Lenovo ThinkPad... | Answered on Feb 28, 2013
It is at the top of the keyboard as shown in the picture
Lenovo ThinkPad... | Answered on Aug 20, 2011
Hello. It appears that you have a problem with your motherboard or the BIOS on your motherboard. When you get the Lenovo logo, there should be a few F# options. Find the one that says "Enter Setup" or something along those lines. You want to try and access the BIOS and see if your motherboard is still working, or if it needs to be replaced. If that does not work, turn off your computer, and unscrew the cover over the RAM. Take out the RAM and reseat it. If that does not fix your problem, I think your motherboard is fried.
Thanks for using FixYa!
Lenovo ThinkPad... | Answered on Jul 08, 2011
The printscreen button should be the button directly to the right of the power button labelled "PrtSc"
Lenovo ThinkPad... | Answered on Mar 30, 2011
Take out the battery, memory, hard drive, and DVD drive. See:
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-71461
for instructions.
With those items removed, connect the system to power and see if anything changes. If there is still no sound and no lights, the system needs to go in for service.
If you get some beeps, try adding one stick of memory back in. If there's no change, try the other stick (if you have one).
If the situation improves, start adding devices back one at a time.
Lenovo ThinkPad... | Answered on Mar 13, 2011
Water and laptops don't mix.l That's a shame. And, many extended warranty agreements will not cover such an accident.
Lenovo ThinkPad... | Answered on Feb 04, 2011
press the FN key and F8..
Lenovo ThinkPad... | Answered on Jun 11, 2010
call THINKLINE: 1800-4267378
for tech support
it seems that it is an issue with the HDD failure and Mother Board.
hope it helps.
Lenovo ThinkPad... | Answered on Jun 10, 2010
If I were you just call THINKLINE: 1800-4267378 in Atlanta GA
if the computer has A LenovoCare Notebook Protection - keyboard replacement and other parts if damaged accidentaly would be free.
however if out of warranty they will tell you on how much will it cost you - but it is cheaper to send to depot with Lenovo than a local tech service.
Only way is to find another keyboard that is broke and take the key off of that and put it on yours. Otherwise you have to buy another keyboard.
Actually this Ebay seller sells keys for IBM keyboards so you wouldn't have to buy the whole keyboard:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290422834687&rvr_id=&crlp=1_263602_263622&UA=%3F*F%3F&GUID=6bb4fc401280a0366331b311ffc5474d&itemid=290422834687&ff4=263602_263622
Or you can buy a whole new keyboard here:
http://www.codemicro.com/store/product/42T406602/New
You have at least a couple of options.
Lenovo ThinkPad... | Answered on May 06, 2010
goto control panel > device manager > sound and audio devices and check for the device status.... if its not working properly the you need to reinstall the driver, this will fix the issue.... or please make sure that did you removed any windows components from add/remove programs.... if so, then do that again and enable all windows components, in that case it may ask you to insert the windows cd/dvd in the cd/dvd drive.....
Lenovo ThinkPad... | Answered on Apr 19, 2010
jrz3305
To bee able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Lenovo ThinkPad... | Answered on Mar 31, 2010
try to drain the battery. take out the battery and unplug the adapter. press and hold the power button and count 1 to 10. release hold after 10 secs. do it for 3 times. after that, put battery and adapter back in and monitor.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo ThinkPad... | Answered on Mar 25, 2010
Lenovo ThinkPad T400 - Intel Centrino 2 Core 2 Duo T9400 2.53GHz Notebook Laptops (276712U) Logo
Popular Tags
39 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Toby Lee
Toby Lee
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkPad Lenovo
  • ThinkPad Lenovo
Most Popular Question
printscreen button
  • Computers & Internet
