20 Most Recent HP Pavilion DV6700T Notebook Questions & Answers
most likely your video card is going south, that is a common problem among HP (DV5000, 6000) and Compaq (5000, 6000) the video card is not getting enough fresh air or is getting too hot, after a while it will just stop working and you would be able to hear but not see Windows.
One technique to fix this problem (is not the best) is to disassemble the laptop all the way to the mother board, isolate components with foil and use a heat gun (some people uses hair driers) and blow in to the video card for about 4 min. that will help some of the card components to stick together again. after you finish doing this put it together and test.
like I said before is not the best option because it will work for a few days maybe weeks and then it will die again plus you can damage other components this is common in 3rd world countries and cheap repair shops.
the other option is to replace the video card most likely ATI right? you have to take the laptop to a repair shop and ask if they have a rework station and a person who knows how to use it. ask if they can check and if needed replace video card some places would charge you about 150 to 250 depends on work quality that would last longer.
if this helps don't forget to rate me
thx
HP Pavilion... | Answered on May 07, 2010
you may have a bad laser
HP Pavilion... | Answered on Apr 30, 2010
Base from the description of your problem this is definitely related to the overheating of your laptop , to monitor if you laptop is getting very hot while playing a game I will advice you to install software to monitor the temp of your computer so you can compare if it shut down on a very high temp and if did what you need to do here is to add some more cooling system on your computer like some cooling fans.
You can download the software from this link,
http://www.almico.com/sfdownload.php
HP Pavilion... | Answered on Apr 08, 2010
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
HP Pavilion... | Answered on Dec 15, 2009
Look carefully at the hard drive that you are replacing. When you take it out of the [mine is a Compaq f750us] computer you might see, for want of a better term, a "STRETCHER" attached to the contacts/connectors, remove it. Put it on the NEW hard drive, put hard drive into computer. Try it again. I did and I did NOT get the "error" code! Why because the HD is now CONNECTED...touches the contacts..
HP Pavilion... | Answered on Nov 26, 2009
Could be a bad hard drive from the sound of it. Since its not letting you go into the operating system. Try do restore your laptop back to factory defaults, if it doesn't go thru or freezes up then your hard drive is bad and needs to be replaced.
HP Pavilion... | Answered on Aug 16, 2009
take out the battery and the mains, hold the on button for 30 sec's, plug the mains back in while holding the on button and it shud *** on... put battery back in when fully loaded up....
Happened to a friends hp laptop and i found this simple fix, should work...
Gerard
HP Pavilion... | Answered on Jul 29, 2009
There are many methods, but the secure and the easiest one is to use Windows System Restore.
It will be located in the Start Menu > All Programs > Accessories > System Tools > System Restore.
There you will select to restore at an earlier point, there will a calender in front of you, with few dates with BOLD format.
Select a date before this event occured.
And restore the system.
Note: You all settings will be restored to that day's settings.
If i was helpfull, Kindly Do Rate!
HP Pavilion... | Answered on Jul 20, 2009
youll have to install another operating system if you do not have the disks
when you format the c drive you erased the partitions with the recovery, know on many acers
HP Pavilion... | Answered on Jul 19, 2009
in your android phone's settings enable or access developer options and turn on usb debugging,( if you don't know how to access developer options you can google your android phones model and android version and how to enable usb debugging) once you enable it just plug it into your laptop and it should recognize it and automatically download the correct driver, if not, go to your phones manufacture's website and look for driver downloads for your model and android version. you can also google this to save time.
HP Pavilion... | Answered on Dec 31, 2019
A DVD player that is an integral part of the laptop does not need drivers to make it play discs. If there is no driver shown, maybe the DVD unit is faulty?
All laptops will play CD/DVD from boot without drivers. The drivers are there to allow you to do specifics to the DVDs.
HP Pavilion... | Answered on Dec 16, 2019
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
To fix 0x80070057 errors you need to follow the steps given below:
Update Windows driver:
An obsolete driver can be one reason for causing this error problem.
Therefore to remove 0x80070057 errors message from your system you need to update your Windows driver.
For that you must
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html also
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
Registry repair: Corruption to the registry can cause 0x80070057 errors to appear. Registry is the storehouse of files and program settings. Therefore frequent access to the registry key can cause corruption to it. Therefore you need to to repair the
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
registry. also http://download.cnet.com/ccleaner/
If the error problem still remains in your system then it is recommended to
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
It might be possible that due to virus or malware has infected your system that's causing 0x80070057 errors.
The anti spyware software will remove the viruses and make your system clean.
Hence increases the performance level of your system.
all of this is freeware
hope this helps
if there are any stubborn drivers
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
HP Pavilion... | Answered on Jul 31, 2019
you can try going into your control panel and look for the speaker icon click in there and you should be able to set your sound settings.
HP Pavilion... | Answered on Jul 15, 2019
The 0xc0000185 error simply means that the computer can't communicate with the CD drive. It could be due to a faulty CD drive or media, a bad connection, faulty interface, bad memory, power supply etc. You will need to isolate the problem further, why couldn't you boot normally? check the BIOS settings again and try clearing the CMOS memory correctly as described in the manual (just removing the battery may not be good enough).
HP Pavilion... | Answered on Jul 02, 2019
I am assuming you are wanting install this on a HP machine, so all you should need to do, is go to the HP website if you use the machine you want to install it on, the web site should be able to detect, your make and model, and if any software is missing it will direct you to the page where you can download the software, and install it in the same way you install any other application in windows.
HP Pavilion... | Answered on Jun 12, 2019
which email service you use go to it
type in your ID name & in the same menu box
look for CAN'T LOGIN TO MY ACCOUNT
and follow the prompts
HP Pavilion... | Answered on Feb 12, 2019
old post, I do only 2018 posts)
first off why the huge contradiction even HP and ASUS mixed.
photo of laptop, and title, NOTEBOOK
and texting a Desktop, but must be a so i moved you....
p6126f PAVILION. it is. no monitor stated, at all. no errors show on monitor, like no signal?
the PC blue light means it thinks its one.
the fans must blow, both PSU and CPU or you have no 12vdc power.
the uSB ports have power, but that happens even with PC in standby mode, or even turned off, that is how I charge my cell phone PC off, using my USB ports,
what matters is:
1: monitor errors, seen
2: Fans.
3; you clicked shut down via what< windows, linux what?
if you CLICKED shut down and the fans don't go dead
that means your OS is corrupted. for sure.
top reasons are bad drivers, and vista can't shut down.
or worse. there is always that. (virus)
I'd DUMP vista, nobody on earth wants to help anyone with a dead vista , horrid VISTA, did you know MS in there great wisdom failed to add recovery mode to vista, yah sux, swap gas. that.
upgrade to w7 and end this silly mess called vista.
w7-64bit is best here, with full HP support seen here.
this is not spam, its the real HP, the place with no malware,etc.
https://support.hp.com/us-en/product/hp-pavilion-p6100-desktop-pc-series/3942799/model/3999655/product-info
HP Pavilion... | Answered on Dec 11, 2018
HP Pavilion DV6700T Notebook Logo
14 questions posted
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
error 0x400110020000100a
  • Computers & Internet
