20 Most Recent
ASUS G Series G50V-X1 NoteBook Intel Core 2 Duo P8400(2.26GHz) 15.4' Wide SXGA+ 4GB Memory 200GB HDD Questions & Answers
Computer is running slow. Tried different browser. Keeps giving me an error saying Adobe Shockwave player plug in stopped working. Re installed Adobe Shockwave and it is still doing the same thing.
Hi Michelle Smith...You may have a virus/trojan/worm in your notebook.To remove a virus,trojan,worm,etc from your computer...do it the EASY way...let someone else do it for you.Start your computer in the Safe Mode.To start the computer in the safe mode: As the computer is starting keep tapping the F1, F2 or F8 Key depending on your computer.This will start the computer in the Safe Mode.Once in the safe mode go to the following webage below and download,install, and run Microsoft Safety Scanner for FREE.Once you run the Microsoft Safety Scanner (it may take quite a while depending on the size of your hard drive) it will remove all the virus's,trojans,worms,etc it finds, if it does not completely remove them all you will be given a chance to chat with a Microsoft Professional thru a pop open window and he will take control of your computer (with your permission) and finish removing all the rest of the virus's, trojans, or worms that are on your computer for FREE!! Can't beat FREE!!Please take time to rate me Bud
http://www.microsoft.com/security/scanner/en-ca/default.aspx
ASUS G73jh Start-up Power BUTTON Problem
Hello ,I can take remote access of your system and fix issue for you, one time charges USD 30; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
Msata asus g55vw
if you're asking "can it be done" then the answer is yes but it is not easy. if your asus is still under warranty, adding an msata drive or RAM on the otherside of the motherboard will void your warranty, if that is not your question, please elaborate.
Asus Laptop G156 - Dual-Core 15.6
The G-series are the gamer (RoG) series by Asus. It might be a G53, atleast that one has a 15" lcd. Of course there are previous RoG's with 15" too, and they tend to hold their cost-level.
Asus G2S back light screen faulty
your bios needs to be reset all you do is open laptop and remove small battery its like the same size as a penny and take out for 30sec and then put back in if that dont work you need to get your gpu checked it might be overheating an reballing work might be needed or feflow i hope that helps
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
