20 Most Recent Lenovo IdeaPad S10-42312CU Notebook Questions & Answers
driver webcam lenovo s 10 e
Lenovo IdeaPad... | Answered on Aug 28, 2016
1.please make sure bluetooth is turned on use fn+(search for bluetooth symbol ie.B)
2.if windows 8/8.1
  • press windows key and type add devices and printer
  • click on the result
  • add device
  • it will show your phone or device to connect
  • connect
  • type pass code
enjoy
if win7
take setting and search like above add device enjoy
Lenovo IdeaPad... | Answered on Jan 02, 2015
You did not say whether the laptop boots up or is dead.
Check the following:
1. Defective Battery will cause laptops to not power up
2. Defective AC power adapter
3. Try vacuuming the open grills on the laptop to suck out any debris clogging the fan
These are about the only things you can check as a consumer without opening the device and troubleshooting at the board level.
If none of these work then the laptop needs to see a MBD (mainboard doctor)
Lenovo IdeaPad... | Answered on May 18, 2014
You contract your service bandor in your area.Thay can help you.
Lenovo IdeaPad... | Answered on Mar 28, 2014
Hi Varsha,
Make sure you have the Drivers and Software installed for the webcam. Go to the Lenovo site and grab the drivers from there, or if it's an external webcam, go to the manufactures site and get them from there.
Hope this helps!
Thanks!
Gary
Lenovo IdeaPad... | Answered on Oct 17, 2013
Run the ThinkVantage ThinInstaller which will download all the drivers for devices connected to your laptop.
Lenovo IdeaPad... | Answered on Aug 06, 2013
You may have accidentally press the numlock button. so, Press again the NumLock button
Lenovo IdeaPad... | Answered on Oct 23, 2012
Just bought Lenovo S10 and so unlucky that window crashed. So have to restore my Lenovo S10 to factory settings. Can’t really find how ot restore to factory settings in Lenovo S10 from the User Manual. So check from google, after many many search, finally found the solution.
For Lenovo S10 to restore to factory settings follow the steps below:-
  • Turn off your Lenovo. (i mean shut down and make sure it’s power off)
  • Now press on the “One Key Recovery” key at the top of your Keyboard, your Lenovo S10 should boot up. Else hold down the “One Key Recovery” key until it boot up.
  • Now you may choose “Restore to factory settings” from the screen and proceed for the restoration.
    ** the restoration will first check if your windows files has been corrupted, if yes, then it will restore it to the original state and no restore is required. else it will continue with the restoration
Lenovo IdeaPad... | Answered on Oct 05, 2012
Hello there! Here you go
http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=43
Good luck! I hope this will help you
Lenovo IdeaPad... | Answered on Jul 31, 2011
Hi rkrkeanz,
Black screen issue often caused by display problem. The easiest way to resolve this is by doing a power drain. Here are some steps that you can apply on how to perform a power drain.
1. Turn off the computer completely.
--> if system is currently on, please press the power button for about 5-10 seconds to be turned off completely.
2. Unplug the AC adapter from the power outlet.
3. Take out the battery from the system.
4. Now, please press and hold down the power button for about 15-20 seconds.
5. Plug the AC adapter and put back in the battery.
6. Turn on the system.
Hope it helps.
Thank you for using FixYa.
Lenovo IdeaPad... | Answered on Apr 06, 2011
There should be a switch just above the keyboard to turn wireless/bluetooth on or off. Make sure this is turned on first. Once you have the bluetooth controller turned on, click on the start icon and open Control Panel. Find and open 'Devices and Printers'. Click 'Add a Device' and follow the instructions to pair your bluetooth device with your PC.
I hope this helps!
Lenovo IdeaPad... | Answered on Mar 02, 2011
It is hard to describe a solution without more information. You may want to try this free webcam technical support guide prior to spending any money on repairs. Best of luck.
Lenovo IdeaPad... | Answered on Jan 16, 2011
CHECK YOUR KEYBOARD
Lenovo IdeaPad... | Answered on Oct 01, 2010
James,
If you remember the date you bought the laptop you can do that. restore the laptop to an earlier date (when you bought it) and it will delete/uninstall all programs that you added to it after purchase. The data will however have to be deleted manually.
Better and faster would be to reinstall Windows from the CDs that came with it. Or from the smaller partition that the original OS resides in. In about half an hour you have your laptop back to the day you bought it.
Lenovo IdeaPad... | Answered on Sep 12, 2010
Could u plz post your query in English...
Rakesh.T.S
IBM Bengalur
Lenovo IdeaPad... | Answered on Sep 04, 2010
hi,
try to press and hold Fn Esc,that will allow you to enable/disabled the webcam,you will see there a small camera icon,if theres a cross in the middle of it,that means its disabled, if nothing happens, go to consumersupport.lenovo.com,type your serial no and look for the camera driver,make sure to verify the designated operating system if it is a Windows Xp,Vista or 7,check also how many bits,if its a 32 or 64bit
thanks
Lenovo IdeaPad... | Answered on Jul 18, 2010
this is the website for the driver for lenovo
just type in the serial number of the computer and look for the driver that match your OS
Lenovo IdeaPad... | Answered on Jun 16, 2010
Need a external CD ROM...
1. Download and burn Ophcrack (freeware).
2. Burn ISO file to a disk.
3. Attach external CD ROM to S10 computer
4. Load the disk with the ISO file in the external CD ROM
5. Turn the S10 on and tap F12 a few times on the Lenovo Screen.
6. Select Boot using CD/DVD ROM
7. Wait for the program to completely load until it shows you a picture with your password on it.c57d3af.jpg
If this solution does not work,
1. Turn off your computer (no flashing lights)
2. Press the Lenovo Care Button (aka One Key Recovery, button with an upside down arrow on it)
3. Select System Recovery.
4. Recovery from factory default settings.
Lenovo IdeaPad... | Answered on Jun 02, 2010
FN+ESC is the on/off switch for the camera/mic. Press both at the same time
Lenovo IdeaPad... | Answered on Mar 27, 2010
Lenovo IdeaPad S10-42312CU Notebook Logo
28 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
lenovo s10 webcam driver
  • Computers & Internet
