20 Most Recent Lenovo IdeaPad S10 - 42312BU Notebook Questions & Answers
Go to this link for help:
http://bootableusb.net/install-windows-7-usb-drive-easy-way/
Lenovo IdeaPad... | Answered on Sep 08, 2015
hoii paano mag hack ng cf
Lenovo IdeaPad... | Answered on Mar 14, 2013
Only you have the password. You can do a System Restore/recovery.
Lenovo IdeaPad... | Answered on Jan 19, 2013
you can't change it. Why would you try.
Lenovo IdeaPad... | Answered on Oct 07, 2012
Welcome to Fixya
Lenovo easy camera is the built in webcam of your computer. You can picture yourself using this camera by using the easy capture software that came with the system.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Lenovo IdeaPad... | Answered on Jun 28, 2011
Hi licah,
It seems that your computer is not booting into windows properly at all.
You mentioned you see Lenovo and windows appear then the screen goes Blank afterwards, you can try to Boot directly into the Hard Drive manually just to get everything working or I mean Booting up again but this is a small shot from what you are experiencing but is also worth the try.
turn your S10 machine OFF then turn it back ON and keep on tapping f12 on the keyboard you should see Boot menu on the list Select HDD then press enter this should boot into the Hard Drive, if it does not then you may need to send the system back to Lenovo for a possible reinstallation of windows or on most time we also have the Hard Drive replaced in many cases.
I hope that this Helps.
Have a nice day,
mvincentc
Lenovo IdeaPad... | Answered on Jun 10, 2011
It would be better if you can just reinstall the Operating System of the machine, if happens that you don't have any important Data on the machine. Here are the steps how you can reinstall the Operating System on you machine.
1. Shutdown the machine make sure the machine is running in AC.
2. Look for the button with the Curve Arrow or Inverted Letter U most likely its near Power Button. Press it once.
3. Wait til you see the message Windows is Loading Files.
4. It will load to the One Key Recovery.
5. Click One Key Recovery.
6 Choose Restore from Initial Backup then Click Next. It will just ask you if you really want to continue, you can just proceed with it.
7. Wait until it reached 100% after that restart the system then you can just setup your Operating System again.
Hope it helps.
Lenovo IdeaPad... | Answered on Apr 16, 2011
NTLDR missing is typical of Windows not findind some system files during the boot, I believe nothing wrong with the hardware.
First enter in the BIOS and be sure that in the boot device list you have the CD or DVD before the HDD.
Second Boot the PC from CD with the Windows CD and try to repair the Windows installation.
http://download.lenovo.com/pccbbs/mobiles_pdf/45n3684_01.pdf
To enter the BIOS Setup Utility, do as follows: 1. Turn on the computer. 2. When the Lenovo logo comes up, immediately press F2 to enter the BIOS Setup Utility.Note: If the customer has set a supervisor password, the BIOS Setup Utility menu appears after the password is entered. If the customer has set a user password, you can start the utility by entering that password; however, you cannot change all of the parameters.
Please let me know if you need more support.
Best regards
Lenovo IdeaPad... | Answered on Mar 11, 2011
You need a Win XP cd , another computer and PeToUSB
Follow the instructions on this link:
http://netbooks.modaco.com/content/msi/261632/installing-xp-via-a-usb-stick/
This link has more in depth instructions:
http://www.techrepublic.com/article/illustrated-walk-through-creating-a-bootable-usb-flash-drive-for-windows-xp/6160062
Click on the links or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Lenovo IdeaPad... | Answered on Feb 05, 2011
what operating sys you running
Lenovo IdeaPad... | Answered on Jan 25, 2011
Welcome to Fixya
This means that windows is already corrupted. Possible cause would be virus issue, recent software installation or windows data corruption. You can still use your computer by restoring it to the origincal facotry state. Turn off the computer and press the small button right beside the power button. It will restore your computer back to original factory state.
Please take note that restoring the computer back to the factory state will delete everything inside the computer. The result would be like you open the computer out from the box.
Lenovo IdeaPad... | Answered on Jan 18, 2011
check the battery life please
tray to take out the battery and check weather the laptop can turn on or off
if on that mean the battery should be replace
regard
Lenovo IdeaPad... | Answered on Jan 16, 2011
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Lenovo IdeaPad... | Answered on Jan 13, 2011
If its a broken LED you need to call LENOVO HARDWARE SUPPORT to replace the LCD
1 877 453 6686 option 2.thanks
Lenovo IdeaPad... | Answered on Jan 06, 2011
Power Management Lenovo Energy Management Lenovo 4.3.1.2 2010-02-01 7.19 MB Windows 7 32bit Lenovo Energy Management Driver Lenovo 3.0.1.4 2009-03-24 3.86M Windows XP HI There,
Go Here:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=43
Go to the "Energy Management" heading and you'll find 2 different drivers. XP and W7. Be advised, RAID or 3rd Party SATA drivers are most often intended to be loaded onto an old fashioned floppy disk. You'll need to have an external floppy drive attached with the proper floppy you've made to make this work.
Also, VERY important. If you're loading the driver for an XP install, the floppy must have been made on/from an XP OS machine or XP Start-up will not recognise the driver.
Good Luck
Lenovo IdeaPad... | Answered on Dec 27, 2010
Use the recovery disk, you will not need your product key.
After you are finished, you can find programs online to read your product key.
Lenovo IdeaPad... | Answered on Dec 26, 2010
Lenovo IdeaPad S10 - 42312BU Notebook Logo
58 questions posted
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
IdeaPad Lenovo
  • IdeaPad Lenovo
Most Popular Question
paano po mag wall hack sa crossfire
  • Computers & Internet
