20 Most Recent
HP Pavilion dv6208nr Notebook Questions & Answers
Hi. We have a problem with microphone on Skype.
It seems that microphone or volume issue on the other end. Can you try recording through mic and playing back? Hope it works, then there is no issue on your end.Your sound settings have such sound recorder options....
DV6208NR wireless
Do you get the wireless auto disconnection or doesn't detect any wifi networks?You may try uninstalling the wireless driver with software removal, windows or the respective OS will install appropriate driver..Please do explain the problem..
Hp6208nr is the computer i
right click on my computer left click on properties choose device manager scroll down to your mini wireless card and see if it has a red or yellow mark on it.If it does click on it and look for the remove device flag choose that and let the operating system re-install the device.Before you do this check to see if the card is disabled if so enable it
Which processer that works faster
Changing a processor on a notebook is not a trivial task. It is very doubtful that you could replace it with a "faster" chip. Best bet is to buy a fast desktop.
How to repair boot-up problem?
just reformat your computer or laptop... make sure you back up your files first when turn on your computer press F8 then safe mode... then you can now back up your important files!
No power not boot need help......
make sure laptop is charged and the adaptor is working fine .if possible then remove the battery and try to switch it on on main power and try if it s work then cool otherwise it need to show it to service center because it is main board issue.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Laptop restarts randomly
A faulty CMOS battery wont cause restart, just the CMOS will prompt for invalid settings on startup.
Common faults that can cause erratic restart are faulty RAM modules, try running computer with only one ram module at the time , to see if one of them is faulty.
A faulty battery can cause this. Run laptop with AC charger only, to test battery.
System faults can cause restart, you need to reinsttall system after formatting disk, installing on top of the old system wont rule out system problem.
Motherboard of graphic chipset can also cause random restart, in that case replacing motherboard is an expensive fix.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
