20 Most Recent
Acer TravelMate 6291-6753 Notebook Questions & Answers
Hello. I am a user of acer travelmate 6291
if the pattern is same everytime you turn on the laptop....
then the problem is with your screen.....and not with any other hardware or software.
if the pattern is not same..then i recommend you to connect another monitor to your laptop and check if you can see similar patten on that screen too..if you do then the problem is with your graphics chip...
hope that helps!
I'm replacing a fan and thermal unit
No, not necessarily the entire unit. Once you remove the chassis cover, the harddrive, optical drive & its fan, then you will see that the processor is covered with the heat sink or another term for it is thermal unit. You will not remove the entire motherboard of this laptop since the thermal unit is placed above the processor wherein the processor is placed at the center part of the motherboard. Another option is you can go to acer.com for manuals or you can call the acer tech support for more tech assistance
Touchpad doesnt work.
if ur touch pad not work than after install .driver of touchpad,ok than it is propearly work done.
Its cannot scan or detect
You need to reinstall the scanner driver in your computer.
Uninstall scanner driver first then if you have scanner driver disk then you can install it fro that disk.
Give me your scanner information so i can give you url for download drivers or your scanner.
Spot like watermark on screen
When you see this starting to develope it is usually indicative of the screen delaminating. The different layers of the lcd may be failing and the picture will start to get more and more destorted. There is no fix except screen replacement.
Intel chipset
go into uninstall programs from control panel and click on show updates box. uninstall sp3.
My laptop after being turned on a blue screen appears and then shuts down
There are many reasons this can be happening. Try starting the computer in Safe Mode with Networking and see if the problem still exists. If not that means there's a problem with the start up boot process. Questions to consider: How old is the machine? Have you done all your updates? Possible virus. What exactly does the Blue Screen read? Is it a quick blue screen then restarts or does the blue screen stays? We are computer service company that offers remote free diagnosis. Call us to today at (877)608-4574 or visit us at www.aplusonsite.org.
HOW DO I DOWNLOAD FACEBOOK ON MY TABLET
I found out in Google that this tablet has Windows 8 on it.
You can install Facebook on it by going to the "Microsoft Store".
If it didn't install, check if your operating system is 8.1
Let me know if that helps.
Why will it not turn on
try taking out the battery and unplugging the power cord from it and then holding down the power button for the count of 5 the long way 1 one thousand two one thousand ect.... this will drain back the power from the board and it just might boot after you plug everything back in again and try to power it back on
Pictures of acer travelmate
https://www.google.com/search?q=acer+travelmate&espv=2&biw=1600&bih=769&source=lnms&tbm=isch&sa=X&ei=BHr3VOfTDJL-gwSMmIG4Bg&ved=0CAcQ_AUoAg
