20 Most Recent
Playmobil Train Station Questions & Answers
Playmobil RC Train set 4018 - have replaced all
Clean the terminals in the remote and at the end of the battery,also inside the battery compartments that holds the battery in the charger and the the train itself. i hadn't used ours for 10 years and hadn't realised that we had left the battery in the train and the 9v battery in the handset. Tried charging it and nothing, but once i had cleaned all terminals of the green residue that had built up, it charged fine and the train ran for 45 mins before needing a recharge.
Hi!
We've just bought our son
Here are instructions to building castle 4866,
http://www.playmofriends.com/forum/index.php?topic=5897.45Also if you are having problems getting the gate to connect to the walls here is the fixThe red circles indicate that there is no proper fitting...after close
inspection and going through the instructions again, I found out that I
need to place the nortwestern corner, green circled, at a different
system -x hole line.....
How to put in the batteries
Mostly it you can see "-" and "+" on the batteries and also on the toy where you should put in the batterires. Then you only have to match the symbols.
