20 Most Recent
Carousel Airblown Inflatable Christmas Santa Express Train Questions & Answers
Inflatable snowman will not fully
if spraying with water allows it to fill up,then yes the material has become worn allowing air to escape. no real fix for this.One idea that comes to mind might be soaking it with a water sealer like spray on wood. this might help seal up the fabric enough to blow up and it is clear.
12/8/2019 7:09:05 PM •
Carousel...
Answered
on Dec 08, 2019
We have a Gemmy airblown
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
11/30/2016 10:36:13 AM •
Carousel...
Answered
on Nov 30, 2016
My Carousel wont blow up all the way
Happened with bounce house and santa just check the motor and it probably doesnt have enough power or it has a small hole in it
Hope I helped ;)
1/9/2014 1:19:06 AM •
Carousel...
Answered
on Jan 09, 2014
Das not get full flow
Have seen a number of problems with these things.... they blow part way up but do not fully inflate...
It seems that the blowers are not big enough and sturdy enough to last very long... after a short time they no long produce enough air to keep the plastic fully inflated...
A couple of things to check first...
Do not use a long extension cord on the blower...
Make sure water is not caught in the plastic making it heavier...
Make sure nothing is caught in the blower and that the opening is clear of debris..
Make sure there are no holes or tears anywhere...this can be hard to check and find...
Did hot light bulbs melt the plastic???
If all of these checkout then the blower just may be getting weak...
heatman101
12/22/2010 1:20:41 PM •
Carousel...
Answered
on Dec 22, 2010
My 16 ft. inflattable santa
Hi and welcome to FixYa!
You may have a hole somewhere that's why it won't go up fully. Please inspect every side of the inflatable santa. You will need to put a patch on the hole if there's any to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
12/15/2010 3:53:28 AM •
Carousel...
Answered
on Dec 15, 2010
