My Tripp Lite 1800 Watt inverter has no output. The indicator lights are on normal. Has 13.5 DC...
(More)
My Tripp Lite 1800 Watt inverter has no output. The indicator lights are on normal. Has 13.5 DC Volts in nothing out. We plugged in a lamp to load the system, nothing.
My 230V Tripplite Smartint700 UPS seems to switch on and function fine - until there is a power cut....
(More)
My 230V Tripplite Smartint700 UPS seems to switch on and function fine - until there is a power cut. The whole system just shuts off. My guess is that this is either because the 2 original OEM batteries in the UPS are dead or the wiring is not properly connected? This morning I took out the battery to get it checked. Meanwhile I am looking without luck so far to find a wiring diagram to see if the wiring is connected to the 2 batteries correctly. I would like to know if the following configuration seems right or not: 1) short black cable connects (+) terminal on battery 1 to (-) terminal on battery two 2) double red cable connects (+) terminal on battery 2 to innards of UPS 3) double black cable connects (-) terminal on battery 1 to innards of UPS Any guesstimates about this or advice most welcome
Tripp Lite OMNI1000LCD UPS Battery 601-12CE9 how to replace the battery and remove it from the...
(More)
Tripp Lite OMNI1000LCD UPS Battery 601-12CE9 how to replace the battery and remove it from the enclosure
I have a Omni 1000 LCD, which is about a year old and it is dead. Before completly going dead it...
(More)
I have a Omni 1000 LCD, which is about a year old and it is dead. Before completly going dead it began to be dead and after unplugging the unit and then plugging it back in it worked fine. This went on for several weeks and now it doesn't work at all. What do you feel is the problem? Thanks, Al
We fix and repair laptop motherboard no video, no pow... Read More
We fix and repair laptop motherboard no video, no power, dc jack, lcd inverter, back light, shorted ac adapter issues down to component level. Cincinnati, Hamilton 45011, West Chester 45069, Fairfield 45246 Ohio OH Laptop PC Computer repair service, Projection bulb TV LCD, Plasma, HDTV, projector repair. Projection bulb TV, LCD TV, Plasma, project
Send your laptop to us and we will diagnose the pro... Read More
Send your laptop to us and we will diagnose the problem free of charge! We repair all over the U.S.A.! Our master certified technicians will run tests to determine the problem and will call you with a quote within 48 hours! Our labor rates are low and very fair. We are proud to be an accredited Better Business Bureau Member with an A+ rating.
Zkarlo.com provides discount and used laptop parts for... Read More
Zkarlo.com provides discount and used laptop parts for thousands of models. We offer Toshiba, Sony, HP, Compaq, eMachines & Gateway, Dell and more!
Choose from thousands of parts, including: LCD Screens, Motherboards, Keyboards, AC Power Supplies, Cases, Hinges, Drives, Batteries and more!
We connect to your computer over the Internet to qui... Read More
We connect to your computer over the Internet to quickly repair your PC. Call Toll Free (877) 729-0812 for a Free Quote. Professional support with certified techs to make your computer run like new again.
We offer computer consulting services, hardware and... Read More
We offer computer consulting services, hardware and software technical support. We specialize in networking design, installation, and support. No job is too big or too small. For the homeowner we offer a reduced rate. We also build our own pc?s and sell hardware and software
Affordable Laptop and Desktop Repair. We spe... Read More
Affordable Laptop and Desktop Repair. We specialize in Laptop LCD Screen repair, Laptop DC Jack Repairs, Laptop Motherboard repairs, Data Recovery. We offer on-site service, local walk in service where available and mail in services.
