Question about T-Mobile Dash Smartphone
Battery? my t mobile dash goes dead all the time and it's fully charged. Do you think it's the battery or something else? i use a razor charger to charge it
  • 2 more comments
  • bkatl Sep 04, 2008
    ive had the same problem, but ive used all different kinds of chargers and got a new battery and it still does it. any help would be good
  • Anonymous Sep 10, 2008
    same problem. however, when i turn it back on sometimes the battery is still charged, sometimes it is not. there does not seem to be any rhyme or reason to this. very frustrating. tmobile recommended a new battery but i am skeptical.
  • Anonymous Sep 11, 2008
    So if we have this same problem of the Dash turning off completely during phone calls and we have used the t-mobile car charger or some other charger we are stuck with a useless phone?
  • ealanjones Sep 15, 2008
    My phone just starting going dead as well. I know the battery has charge to it because I will start it up and it has 3 bars of life.
If you have your wi-fi running all the time and if its constantly searching for wifi service it wil eat up your battery in like 5-6 hours, and make sure you use ONLY t-mobile dash charger, it does make differance,
Posted on Sep 09, 2008
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
on Jun 19, 2015 | Razor E100 Electric Scooter
I have had my e100 electric scooter for a about 2 years i havent actually used the scooter in 12 months so today i plugging in into the wall with the charger and there is a green nonflashing lite on the...
The charger light should normally be red if the battery is accepting a charge and green when the charger goes into trickle charge or off. SLA batteries do not last well if they are not regularly given a top up charge. I suspect the battery needs replacing.
If you have access to a voltmeter then you can test the battery voltage at the charger input port on the scooter.
There are lots of places that sell Razor E100 scooter parts and provide resources/information on replacing the battery.
Here are a few: http://www.razorama.com/
http://www.scooterguru.com.au/
http://electricscooterparts.com/
http://www.monsterscooterparts.com/
Jul 30, 2013 | Health & Beauty
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
Razor charged but not running
You didn't specify how old you model is.
Generally I would say, the battery is failed.
You might try taking it to whereever you bought it and politely ask for a replacement. Its also a good idea not to leave these in cars during sub freezing weather.
Apr 09, 2010 | Norelco Cool Skin 7775X Electric Shaver
T-mobile dash turns off at random times
had the same issue, its most likely the battery. i've read if you're not using the right charger designed specifically for the HTC Dash, then whatever charger you're using can overcharge and eventually kill your battery. I bought an all new battery off ebay for 12 bucks and ordered a new charger for another 10, solved my problem right away.
Mar 29, 2009 | T-Mobile Dash Smartphone
I have a T-Mobile dash and cannot get it to charge.
Do you have other phones or chargers? Most Motorola cell phone chargers will fit the dash as will some digital camera chargers.
Apr 07, 2008 | T-Mobile Dash Smartphone
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
T-Mobile Dash Smartphone Logo
Top T-Mobile Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
