Question about HP Computers & Internet
HP w19b "shadow"
Not sure if I would call it ghosting or not, but everything (especially black text on white background) seems to have a shadow to the right of it. Especially noticeable with bold text and larger fonts. Saw one "generic" fix for "ghosting" that recommended a cable replacement but don't want to spend the $ if we're really talking about something different. Have updated the driver and attempted various adjustments (focus, etc). The OSD is NOT shadowed or "ghosted"
  • 1 more comment
  • MikealS Sep 02, 2008
    The display adapter is on-board (Dell computer) and uses the Intel g33/g31 express chipset
    Naturally, the FIRST thing I did was to reset everything to factory defaults.
    Thanks will give it a try.
  • 10,594 Answers
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Posted on Sep 02, 2008
    Genius:
  • 1,847 Answers
Try restoring the monitor setting to default factory setting.
    Brigadier General:
  • HP Master
  • 3,614 Answers
What is the video card you are using?
  • 1 more comment
  • micromaster
    micromaster Sep 02, 2008
    first try to update your vdeocard driver
  • micromaster
    which one u will give a try?
  • micromaster
Hi, my syncmaster p2270 seems to have some kind of focus issue. Everything is sharp, but to the right of the visuals on screen there is a duplicate, reflection of whatever is being displated on screen....
Hi Jonhy, on the pc , try this steps:
1. At the mainscreen mouse rigth click and go to Properties
2. Go to Definitions and Advanced
3. A window with graphic board's properties will come up and the choose 3D setup/config (depending on graphic board mark)
4. Change from Direct 3D to OpenGL and then Apply and OK to close.
This procedure is to change from hardware aceleration to software aceleration of image on screen. As that it will be sent only one kind of image definition from the pc to the screen with no repeating or mirrowed data. Hope it will helps you.
Nov 04, 2013 | Samsung SyncMaster P2270 22 inch Monitor
Shadows/ ghost images...
i'm also had the same problem and don't know how to solve it. anyone can help?
Apr 03, 2012 | Wacom Cintiq 21UX
I have a hp w19b moniter and everything is hooked up even the speakers. However the speakers have yet to work. I have made sure there plugged in and everything.
The speakers in this monitor require a powered speaker output, and most audio cards only provide a line level output, which is not enough to drive these.
You may need to go out and get another sound card like a creative labs or the like - but make sure the card has a SPEAKER out on it, and not just a line level output.
You may be better off simply going out and getting a set of powered speakers!
Jun 22, 2011 | HP W19b LCD Monitor
Ghost printing preceeding page images and or text
1.Most likely is the fuser assy, depending on what your page count is. 2.Could also be your toner cartridge especially if it is a reman
Dec 08, 2009 | HP LaserJet 4345mfp Printer
PDF not showing any white text on black background
You need as much memory available to you as possible.
Add some more RAM to the computer.
Increase the swap space size.
Close down all other applications and background processes. Close down internet access especially and make sure that Internet Explorer is not running.
Nov 08, 2009 | Microsoft Publisher
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
Feb 16, 2009 | HP L1706 17" LCD Monitor
Canon PowerShot A620 Photos have shadows
I was having this problem and found I was placing finger to close to the flash when I was steading the camera.
Aug 23, 2008 | Canon PowerShot A620 Digital Camera
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Ghosting problem with Christie LX 45
reset the settings to factory default and make sure the resolution matches. you can adjust the clock and phase in the menu.
Nov 16, 2007 | Christie LX45 Multimedia Projector
Computers & Internet Logo
549 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
