Question about LG Dishwashers
Hi, I washed a candle, yes candle, in my daughters brand new lg dishwasher and now it doesnt work. Surprising i know. After spending days tearing it apart and removing all the wax out of the inside as well as pipes and hoses, etc it will now do everything but drain. Can you help?
  • kaydburke Sep 03, 2008
    Sorry, it is LDF8812ST and i had trouble finding it also, but on the LG site it does come up but no helpful info only the users manual which i have. If i could find a schemtic or service manuall like the site you gave me originaly did it would be so helpful, But i have been unalbe to find such for this model. Thanks so much for trying. I hope you have better luck than i did.
  • 706 Answers
The problem is that when you ran a wash cycle.. the heater came on and melted the candle and some wax probably ended up in your pump or hoses in/out of that pump.. Since you did not provide a specific model number, I cannot provide specific details on how to dismantle everything but here is a link that you can get service manuals etc for LG products. Hopefully, yours is listed there and the details will be clear enough for you to clean everything up and get water draining again.
You might also find a detergent ( I am thinking liguid plummer or something ) that might break up any wax residue without having to open everything up to clean it.. Good luck and hope this helps you...
Posted on Sep 03, 2008
  • Rick Gelin
    Rick Gelin Sep 03, 2008
    The model number ldeg8812bb you provided does not show up in my search at the LG site.. are you certain this is the Model Number.. Please check again and I'll continue looking for more info for you.. Regards..
  • Rick Gelin
    I'll give it a try and get back to you... hang in there...
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
Brand new LG LDF6920 makes a whistling/high pitch squealing noise even during 1st test run, no dishes no contaminants added. It is during the wash motor cycle once the wash pump gets up to speed *screech*....
I had a brand new Dishwasher do that, it wasn't an LG it was a Frigidaire i think, turned out to be some bits of plastic from the manufacturing process that were in the pump. I had another one that made thumping noises and turned out to be a little piece of the tape, you know all that blue or green tape they hold everything in place with when its new. Did you run it through a few cycles and see if the noise quit? Believe it or not when i called about the one that was squealing their customer service said to run a couple cycles to remove anything that might be in the pump from manufacturing, sure enough midway through the second wash cycle it just went quiet and never made another noise again after two years.
Jan 11, 2018 | LG Dishwashers
I spend more time washing my dishes after they go through the dishwasher, not worth have it. Especially the glasses, is there anything else I can do to prevent this, is there some kinda of filter to clean?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things...
Bought new spray arms online and installed them in the thing works like new...
However I have also found that if the heating element goes bad then that also can mess things up bad...
So I would buy new spray arms, and also check out the heating element to make sure it is working...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Sep 24, 2010 | LG LDF6810ST Stainless Steel Built-in...
I have a brand new LG dishwasher-LDF6920ST. I
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
First Choice Appliance
Feb 05, 2010 | LG LDF6920ST Stainless Steel 24 in....
Is a LG 6810 dishwasher that is 3 yrs. old a good 2nd hand buy?
The Brand New Machine would cost you around $700. So, you need to take a Dishwasher is around 7 - 10 Years. So, you are left with 4 - 7 Years to Use this. Every year there is a decrease in the Value as well.
LG Dishwashers are usually Cheap and Reliable. But, when i Read the reviews for this Model ( Remember, it's only the reviews i read in different forums and review sites ), the value of money for this Model is Negative.
Check one of the Best Sites for Reviews :-
There are many other. Google and check it. It's a Different case, if you are getting that Dishwasher around $150 - $200. Then, it's worth :).
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 11, 2010 | LG Dishwashers
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Hope i helped you.
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
I have a new LG Dishwasher LD120W1 purchased on 6/11/09. Have only used it approx 3 times. When I turned it on today it started up and after a few minutes it starts whistling and does not fill. Have...
I would Glad to tell you what needs to be Done!! But, as the Dishwasher is Under Warranty, give them a call. Why to spend any Money, when the washer is under Warranty :)
It sounds like a Water Pressure Problem. Make sure that the Water Pressure should be OK. If yes, more often you need to Replace Water Valve.
To Test Water Inlet Valve
It could be Kinked Hose, but as you already Checked it, it eliminates that Part.You could also Check Float Switch :-
Hope i helped you.
Dec 22, 2009 | LG Dishwashers
Don't buy this brand anymore, and be sure all your friends know not to also. I have a GE, GSD4000J, it is less than 2 years old, I have used it maybe at most 6 times. Now it will not drain, washes with the same water, does a terrible job of washing. I own a remodeling service, I will never buy GE products for any of my jobs from this day forward. Have not been able to get any help from GE, they don't seem to stand behind their products at all, or care about their customers once you have bought their products.
Oct 30, 2007 | Dishwashers
Dishwashers Logo
183 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
