Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Agitator Dogs Your instructions on replacing the dogs are really straightforward, but the dog assembly didn't just fall out as you suggested. Any more ideas on how to remove the dogs? I have the agitator assembly completely removed.
  • 1 more comment
  • bsnangle Sep 16, 2008
    Will not agitate
  • fmb123 Dec 08, 2008
    I have a similar problem, supposedly I'm just to pull up hard. But I can't get the top half of the agitator to seporate from the lower half. I can see the dogs down in there and they need replaced, but can't get it to come apart. Any suggestions? Is there something silly I haven't figured out? :)
  • Anonymous Mar 29, 2014
    male dog names
To disassemble, you need to destroy the tabs that are holding the translucent thing to the four post on top of the bottom part. This of course means that the translucent thing needs to be replaced too. I hammered the screwdriver into the tabs until they gave way. The rest of teh parts come out undamaged.
(if you have snips with really long handles, that would be a better tool).
Posted on Dec 12, 2008
  • 126 Answers
TO REPLACE THE DOGS IS A VERY COMPLICATED ITS BEST YOU GET A TECHNICIAN TO RESOLVE THE PROBLEM.GOOD LUCK
Posted on Sep 10, 2008
Trying to replace agitator dogs. Removed cap and nut, and have whole agitator assembly in hand(one large unit). However I cannot get the dogs out, as the inner assembly won't fall out. How do I...
See the following illustrated descriptions:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=bb1287f031ea458c3a91d1feb88faaa8
Nov 03, 2010 | Washing Machines
Tip
Replacing Agitator Dogs
The following advice is for replacing the Agitator Dogs on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10.
The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are Agitator Dogs? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Agitator is not agitating. It slips How to repair or replace?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2010 | Washing Machines
How can I fix the agitator on my washing machine?
Sep 14, 2010 | Kenmore Washing Machines
Grinding noise and agitator wont turn
If this is a Whirlpool manufactured TOP LOADER, an agitator problem can have several causes. Most commonly, this is caused by a broken motor coupling. The following link explains how you can diagnose the problem and repair:
http://www.fixya.com/support/r3965207-whirlpool_top_loader_no_spin_problem
I have included parts sources and instructions on how to replace any parts as well.
If this just a simple matter of the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Last of all, the most expensive problem that can occur, is a failed gearcase (transmission). The gearcase averages between $80 and $160 to purchase. If you wish to replace the part yourself, it is not that difficult. The following link explains how:
http://www.fixya.com/support/r3576575-replacing_a_gearcase_on_whirlpool_manufa
The procedure is rather lengthy, but not as difficult as you would think. It can save you a lot in labor charges.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the following part numbers you may need:
Motor Coupling 285753A
Agitator Cam Replacement Kit 285809
Agitator Dogs 80040
Gearcase 3360629
NOTE: If you replace the gearcase, replace the motor coupling as well.
If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
The agitator is not moving as well as it should. It turns very little. Should it not be agitating aggressively?
You have (agitating dogs) in the bottom of your washing machine. These little plastic pieces tend to wear out over time or from overloading. These can be replaced, cost about $5 for for 4 of these (dogs). Take the very top piece of the agitator off, it spins off. There's a bolt in the bottom of the agitator that will have to be removed. After it's removed, you can pull the agitator out. You will see the little (dogs). It's a very simple task, and takes about 10 min to do this. Look up (picture of agitator dogs) this will give you a better view at what you are looking at.
Mar 04, 2010 | Roper RAX4232KQ Top Load Washer
I have an Inglis Sterling washer. The 'dogs' as they are called need to be replaced....I have disconnected the dual agitator from the washer. I am unsure how to disconnect the plastic housing that holds...
Aug 30, 2009 | Washing Machines
Kenmore 70 series washer still won't agitate or spin. I changed the agitator ''dogs'' and...nothing. Can I please get step-by-step instructions on changing the coupler? That's my next solution. Also,...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
Aug 10, 2009 | Kenmore Washing Machines
Clucth Dog replacements in Agitato
Feb 02, 2009 | Washing Machines
Trying to connect agitator without dogs getting out of place
I thought the two parts would snap/connect together. They don't. Put the agitator on upside down over the "dogs" and their connector. Holding that together put the top agitator over the bottom. Carefully put over the metal connector inside the washer and connect the bult. The bult is what holds the pieces together.
To take apart initially I had to use a socket set with a long extension and a pipe over the racket handle to get enough torque to loosen the bult
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
136 people viewed this question
Dan Webster
Dan Webster
Sal De
