Magellan eXplorist 400 GPS Receiver
Problem for Magellan eXplorist 400 GPS Receiver
Replacement parts for Magellan eXplorist GPS
By H2odowg on Sep 02, 2008
I am looking for a replacement rubber keypad membrane for my eXplorist 600. Can you help?
I am also having a keypad problem with my Explorist 400. The "zoom in" button will not work. I took it to an electronics repair shop and they said the keypad was not working properly. Any suggestions where I can get a replacement keypad?
Same Problem
Mar 13, 2009
-   Zoom in button on Explorist 400 is malfunctioning-   Guest
Best Solution
posted on Dec 01, 2008
Very Helpful)
jaredyates
Rank: Apprentice
Rating: 100%, 2 votes
The keypad is integral to the circuit board. You can replace the rubber membrane cover, but not the buttons. I have a few extra rubber membranes, if you are still looking. junk@jaredyates.com
Comments:
Apr 27, 2009
- I don't have any more membranes left... I would suggest looking on ebay for a broken GPS if you need one.
Was this helpful?
Yes
No
Solution #2
posted on Apr 27, 2009
Very Helpful)
ortona
Rank: Apprentice
You need to be brave, but it is pretty simlple. Basically you are going to clean the rubber keypad and circuit board contacts. These contacts develop a film over time that needs to be removed. That is the main reason telephone and remote control keypads fail over time.
1. Remove the battery.
2. Remove 5 screws holding the bady together and separate the backplate from the main body.
3. Now carefully lift the circuit board out of the main body. Do not disconnect anything, but be careful with the rubber seal that fits between the back and front plates.
4. With the circuit board laying flat on your work surface, remove the rubber keypad. It is held in place over the joystick. Carefully lift it off the joystick and set it aside.
5. Use a clean pencil eraser and lightly rub the contacts on the circuit board. Do the same thing on the keypad by pushing the little knobs out where you can rub them. Blow away the dust.
6. Use a Q-tip with some alcohol to clean the contacts on the curcuit board and on the keypad.
7. When the alcohol is dry, put everything back together in the opposite order.
This should be good enough, but if it does not solve the issue, then buy a rubber keypad repair kit (an example is at http://www.mgchemicals.com/downloads/appguide/appguide0206.pdf) and try again.
Good luck.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Magellan eXplorist 400 GPS
Questions and Unsolved Problems for Magellan eXplorist 400 GPS
Do you recommend Magellan eXplorist 400 GPS Receiver?
Answer
Answer
how to solder power jack for the roadmate 300
Answer
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS!... (More)
Answer
I tried to update my magellan explorist 400 firmware. A sudden power interrupt forced my computer to... (More)
Answer
i want the gps to show me where i am heading like the gps in my car. how do i do that?
Describe your GPS Devices problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Device Experts
Top GPS Device Repairmen
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
