Question about HP iPAQ H5550 Pocket PC
WPA-PSK and AES
Hi, Does the Ipaq 5550 support AES key encryption or onl TKIP as this seems to be the only option available under WPA-PSK. If it does support AES how do I enable it? Thanks
    Master:
  • 450 Answers
On my ipaq hx4700 , i'm only able to use wpa-psk tkip, no aes option. not sure if any difference on 5550.
Posted on Sep 14, 2005
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
Nov 24, 2011 | NetGear Computers & Internet
I am trying to get on the wii internet like i always could but it loads for 30 sec. to 1 minute. the it says error code: 51332
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using WPA encryption, the Wii is compatible with :
  • WPA - PSK(TKIP)
  • WPA - PSK(AES)
  • WPA2 - PSK(AES)
If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings.
Jul 28, 2011 | Nintendo Wii Console
Muddytrying to go to netflix, from my WII says my internet connection is not working, but my laptop in on and working.
Greetings,
Did you recently change your encryption or password on your wireless network? It may not work if you are not using one of the following encryption types:
  • WEP
  • WPA - PSK (TKIP)
  • WPA - PSK (AES)
  • WPA2 - PSK (AES)
Try re-entering your wireless settings on the Wii to match the settings on your laptop.
Apr 17, 2011 | Nintendo Video Game Consoles & Games
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
Pls help me to set a password on my Wifi, thanks
From the HOME page (192.168.11.1),
Basic Settings > Wireless > Wireless Encryption (WEP/TKIP/AES), select TKIP or AES. - or - Hit Advanced button at top right of HOME page.
Wireless Config > 802.11g, under Wireless Encryption choose TKIP or AES, you can input your WPA-PSK (Previously Shared Key) Use 20 Character Key!
Use a minimum 20 character WPA Key.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 10, 2010 | Buffalo Technology WHR-G54S Wireless...
Error code 52030 ,when trying to hook up to wireless internet
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Mar 11, 2010 | Nintendo Wii Console
Can't get wii connected to internet, keeps asking for key code.
It could be that the encryption method on your router is not supported by the wii. It also may be that you are using WEP and trying to connect in the 2,3, or 4 spots. The wii for whatever reason can only connect to WEP in the number 1 slot. The Wii is also compatible with WPA types WPA - PSK (TKIP), WPA - PSK (AES), WPA2 - PSK (AES). Check your router and try again.
Jan 14, 2010 | Nintendo Wii Console
'the key information exchange timed out'
Is your wireless network encrypted with WPA-PSK(tkip)? If so change it to WPA-PSK(aes) and the PS3 will connect without problem.
Sep 04, 2009 | Sony Playstation 3 (PS3) Console
Need security option
The security code is set in the wireless section of the router. You need to access the router's setup page and go to wireless. Under security you will see the encryption key which you need for your adapter.
The setup page is at 192.168.0.1. Put that in your browser.
It will open to the router's setup page.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is password. Click the Ok button to log in to your router. Then go to wireless tab, then security.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 19, 2008 | Blitzz Technology (BWP712) 802.11g/b...
HP iPAQ H5550 Pocket PC Logo
1,022 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
