Question about Dell Axim X5 Pocket PC
Does Axim Have a serial Connector
I checked the specs, couldnt find much on it, all of the devices i connect to use serial, no usb, although i can get a usb to serial connector, does the Axim have a serial connector?
    Sergeant:
    Champion:
  • 333 Answers
Socket sell a CF card adaptor which will provide a neat solution.This provides a 9pin RS232 output with programmable baud rate.
Posted on Feb 03, 2008
    Master:
  • 852 Answers
From what Dell shows in their downloadable manual there may be a fabled serial connector from the cradle and the travel cable. Dell does not offer it at this time. I only read once that Dell may offer if Mid Jan. I would bet that you would have better luck waiting for an aftermarket company to make one *IF* the unit supports serial. I honestly don't see why Dell wouldn't offer serial but there is always that chance that they will support USB only. I have yet to receive my unit.
Posted on Sep 14, 2005
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
My Dell PDA won't sync with my PC, although it used to?
1)If you get an error message from ActiveSync on your PC, it's one of a million things that can and do go wrong with another piece of Micr0$0ft'$ "finest". I wont even go there in this post. 2)If it just never gets seen by the PC, check your USB cable connection. 3)If the PDA doesn't even turn on and/or charge immediately when connected to the cradle, you may have a bad cradle. 3a)If the connector in the cradle feels lose or it DOES connect if you hold it a certain way, your cradle's broken. They're known for this.
Oct 07, 2009 | Dell Axim X51v Pocket PC
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
MY DELL AXIM X30 WILL NOT TURN ON
My Axim X30 would not turn on using battery power but would turn on when connected through charger adapter.
Solution:
1. Connect AC adapter directly to the charger adapter and then to the Axim X30 and to the electrical outlet.
2. Charge battery until power button is solid green.
3. Press the power button to power on.
4. Remove cable from cable connector leaving the cable connector connected to the Axim X30. The Axim X30 will remain powered on.
5. Turn the Axim X30 off.
6. Turned the Axim X30 on using battery power.
7. Remove cable connector from Axim X30.
Apr 07, 2009 | Dell Axim X30 Pocket PC
Can't go on internet
A few suggestions for you:
Have you already installed the drivers and software ? If so, check the manufacturer's website for driver/software updates and install them if available.
Check the router's firmware revision and update that if possible. Many wifi issues are the fault of the AP and not the Axim.
Some people say that open is more secure than shared, while others claim otherwise. The difference is in the authentication encryption. There are valid arguments to both, but the fact is that neither is secure. If you're concerned about security, wait for 802.11n, although it may be cracked before its spec finalization like most things “secure”...
Also, check if MAC filtering is checked or not. If it is checked, either enter the Axim's Mac address or simply disable it.
Sep 16, 2008 | Dell Axim X50v Pocket PC
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Dell Axim doesn’t support serial connections?
There is another thread on this board where a number of people talked about serial connections and alternatives. I also want to connect my existing AirMap 100 GPS via serial cable. The Dell moderator (Rollie) pretty much put an end to that thread by stating: "A serial cable is not available @ this time and when one will be available is unknown"
Can the sync cable be used for regular serial or usb connections to external devices such as GPS devices?
No the Axim does not support Serial Interfaces at all. It also doesn't have USB Host capability.
Dell Axim X5 Pocket PC Logo
166 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
