Toshiba 61H70 61-Inch HDTV -- Projection TV has problems.... We see a mirror image of whatever is being displayed and is in blue color. Like if I open the menu bar it diaplays a mirror image of the menu bar right below the menu in blue color. Can you tell me what is the problem.
  • Crgallen22 Jan 17, 2009
    I am having the same problem. A blue mirrored image is displayed just above. This is occurring only from the middle on down. Any suggestions? The television is a Toshiba 61H70.
  • 1030 Answers
SOURCE: Toshiba 42 inch rear projection T.V.
this sounds like a convergence loss... the most likely cause of this is what is known as stk's or convergenc ic(chips) have gone bad.. also it cound be the output resistors. most likely need replaced
Posted on May 12, 2008
Mr Alexx Sir
  • 12 Answers
SOURCE: TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Posted on Jul 29, 2008
  • 185 Answers
SOURCE: toshiba 55 inch hdtv lamp
this is a crt type tv- no lamps just crt's if it was moved recently then a seal could have been damaged on the crt cuasing coolant to leak down the neck getting into the socket. this will cause trouble for sure also could have a crack in the crt. look for a sticky liquid in the bottom of the unit.
sometime the crt's can ark and rip out a video output chip on the crt socket check it out.
not common but not unheard of.cheers
Posted on Oct 08, 2008
Ecollier2012
  • 3459 Answers
SOURCE: color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Posted on Jul 10, 2009
How can you tell if the bulb is burned out on a RCA 52 inch projection
If you are missing one of the colors but still have an image (red, green or blue). Real simple, turn on the TV and see if there are any colors missing from those. Most rear projections have a color bar you can put up or a converge feature which is used for aligning the colors for a clear picture.
Aug 31, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
My toshiba 57 inch rear projection tv every once in awhile makes a loud pop similar to a spark noise and the screen either goes black or flickers. do you have any suggestions what is causing this??
THis could be one of the CRTs (Color Tubes) is bad or the high voltage is leaking somewhere.
Toshiba projection TVs have history of yoke problems.
My guess is one of the CRTs is arcing inside. This TV has 3 CRTs red, green and blue. Replacing a CRT is not easy or cheap to buy if you can find it. If you like this try calling a TV technician to track down the high voltage arcing. DO NOT TRY TO DO THIS BY YOURSELF.
Best of luck my friend.
AAA TV SERVICE
Jun 12, 2011 | Toshiba 57H84 57" Rear Projection...
My Toshiba 42H83 has developed a color problem. The color blue is about an inch off the other colors, the picture looks like a 3d movie without the glasses. I have used the touch focus button on the...
Alot of rear projection t.v.'s have a convergence option in the menu on the t.v. There you can set the try to set the colors back how their supposed to. Mine has a cross in the middle of the screen and you just have to try to get all 3 colors to line up. Unfortunately, the actual lens inside mine has to be aligned so it doesnt work. Just something to try though, hope it helps.
Jan 05, 2010 | Toshiba 42H83 42" Rear Projection...
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
Old toshiba
Hi Veronica,
I need to know exact model number of your Toshiba TV to help you out.
You can find it at back of TV on some kind of sticker.
Oct 11, 2008 | Zenith R49W36 49" Rear Projection HDTV
May 12, 2008 | Toshiba 42H83 42" Rear Projection...
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Mar 17, 2007 | Toshiba 53HX71 53" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
