Question about Samsung SC-D103 Mini DV Digital Camcorder
Does not record and playback doesen't work
When i put a tape in an eject sign with an R flashes on the screen
    Scholar:
  • 107 Answers
Your problem is the drum motor is not turning it require a Tech from Samung depend your area or country they change just the drum motor assembly or they change a complet deck assembly
In AUSTRALIA it cost about $100 to replace drum motor and $150 to replace a deck assy
I hope that give you some ideas
Posted on Dec 05, 2008
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony ccd trv218e, recording & playing back does'nt work
I had that problem also and I found that using smaller tapes helped. I was using the 120 minute tapes, I think they may be too heavy.
Feb 13, 2009 | Sony Handycam CCD-TRV21 Camcorder
Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Nov 03, 2007 | Sony Handycam DCR-TRV250E Digital...
Image and sound problems at playback
your tape guides are out of calibration on all your pre - recorded tapes , or they are out of adjustment ( maybe even loose ) now ; - - put your camcorder close , next to your ear ? and . . . listen ! to a new tape in play mode - if you hear a fluttering sound like a deck of cards being shuffled softly , the camera is damaging all your tapes and needs alignment ;
Jul 28, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
Samsung SC-D103 Mini DV Digital Camcorder Logo
107 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
